Viewport framerate does not exceed 120 fps where expected
Operating system: Win10
Graphics card: 980ti
32GB memory
SSD
Broken:
2.80 2019-02-10
Frame rate does not exceed 120
Base framerate modifier has no effect when multiplier exceeds a value of 120fps, even though it would imply it would mathematically resolve and it selectible in the interface; the viewport never exceeds 120 frames/sec.
Christopher_Anderssarian lowered the priority of this task from 90 to 30.Feb 21 2019, 9:31 AM
Most likely a VSync issue, especially if it's exactly 120Hz. Try disabling it in the Nvidia control panel.
But also: What playback sync do you have set?
Brecht Van Lommel (brecht) changed the task status from Unknown Status to Unknown Status.Feb 21 2019, 12:23 PM
We indeed follow the monitor V-Sync, by design.
If your monitor can't refresh more than 120 times per second, there is not much point to redraw at a higher rate.
I'm asking that physics simulation and scene respect the frame rate beyond the the draw rate for viewport rendering.
Please reopen this as a feature request
For feature requests, see:
https://wiki.blender.org/wiki/Communication/Contact#User_Feedback_and_Requests
Physics simulation systems often already work at subframe steps though, quality of the simulation should not be tied to redraw frame rate.
