Cube metaball are broken
OS: Windows 10
GPU: Gtx 970
Broken: 2.80 1af810b4ff17 2019-02-20
Cube metaball are broken in multiple ways (other metaball are fine):
  • Their selection ring isn't visible
  • Weird behavior when deleted and added
  • Default startup
  • Add a cube metaball
  • Duplicate it with Shift+D
  • move it next to the first metacube
  • Delete one of the metacube
  • Both disappear and only a selection ring remains
Additionnal note : to see the meta cube again you need to readd another
Quick video to illustrate the problem:
After test, it was broken in 2.79 as well
Sebastian Parborg (zeddb) lowered the priority of this task from 90 to 50.Feb 22 2019, 11:10 AM
This also happens with the other metaballs.
You just have to delete the first one you added and the others will vanish.
Jeroen Bakker (jbakker) closed this task as Archived.Jan 21 2020, 11:54 AM
Jeroen Bakker (jbakker) claimed this task.
Jeroen Bakker (jbakker) edited projects, added Modeling; removed Tracker Curfew.
This is a limitation of the current implementation where the first Meta balls is the parent of the group. The group is determined by the object name. A better solution would be to have a proper group or use the collection system. But not considered a bug.
