Windows 10, 1060
Broken: 2.80 master (also reproduced in a month-old daily build, so not new behavior).
If you have an active tool like Add Cylinder going, and you hide another object using the eye icon in the outliner, then as soon as you touch the cylinder parameters, the hidden object becomes unhidden.
- From the default scene, Add a Cylinder to the scene and expand the tool properties in the lower left of the 3dview.
- Because the cylinder is hidden inside the cube, we can't easily see the effect of changing the tool parameters, so go to the outliner and click the eyeball icon associated with the cube to hide it in the viewport.
- Change any parameter in the cylinder tool properties pop-up in the 3dview. The cube reappears and the eyeball indicates it is no longer hidden.
Basically any changes made to the Outliner visibility icons gets reverted as soon as you change any active tool property, (at least for the Cylinder tool). This at least unexpected behavior.
