Crash on Eevee render (MacOS)
Operating system: macOS Mojave 10.14.2
Graphics card: Radeon Pro 560X 4096 MB
Intel UHD Graphics 630 1536 MB
Broken:
2.80, 9541ce2c261b, blender2.8, 2019-02-22
Download file is blender-2.80.0-git20190222{F6683098}.9541ce2c261b-x86_64
Blender crashes when rendering and textures are wonky on Rendered View (And all textures don’t render on complex scenes)
Start rendering scene, it freezes for a while and crashes.
Related Objects
It also crashes when I enter Sculpt Mode. And when I add a Collection Instance the hair particles go elsewhere. :P
On further testing: Collection Instances might be the problem. When I delete them I can sculpt again and render finishes just fine.
Sebastian Parborg (zeddb) lowered the priority of this task from 90 to 30.Mar 4 2019, 3:30 PM
Can you attach the output of --debug-gpu and see if --debug-gpu-force-workarounds helps?
Here is the Terminal output. Is this what you asked for?
Tried opening via Terminal with --debug-gpu-force-workarounds and it still crashes. Tried on another slightly heavy scene as well and it crashed too.
Sebastian Parborg (zeddb) raised the priority of this task from 30 to Normal.
In a slightly heavier scene I'm working on, my MacBook crashes to the point I have to reset it. When I disable some of the render options it renders okay.
Not sure this is the only problem, but this is a simple example file for the crash:
  1. create a cube
  2. add particles
  3. instance the cube collection to the scene
  4. render
see the crash log from blender and the report from the system below:
# Blender 2.81 (sub 8), Commit date: 2019-09-06 19:05, Hash 9ecbd67dfb67
# backtrace
0   blender                             0x000000010431e087 BLI_system_backtrace + 55
1   blender                             0x000000010405b54b sig_handle_crash + 363
2   libsystem_platform.dylib            0x00007fffbb73cb3a _sigtramp + 26
3   ???                                 0x00007feda29444d0 0x0 + 140658611602640
4   blender                             0x00000001041fa819 BKE_object_free + 25
5   blender                             0x000000010433de68 _ZN3DEG32deg_free_copy_on_write_datablockEP2ID + 504
6   blender                             0x000000010434494b _ZN3DEG6IDNode7destroyEv + 59
7   blender                             0x0000000104346010 _ZN3DEG9Depsgraph26clear_id_nodes_conditionalERKNSt3__18functionIFb7ID_TypeEEE + 112
8   blender                             0x0000000104345d73 _ZN3DEG9Depsgraph14clear_id_nodesEv + 115
9   blender                             0x0000000104345c0f _ZN3DEG9DepsgraphD2Ev + 15
10  blender                             0x0000000104346566 DEG_graph_free + 22
11  blender                             0x00000001043aff3f RE_engine_render + 1151
12  blender                             0x00000001043ba60f do_render_all_options + 399
13  blender                             0x00000001043ba122 RE_RenderFrame + 370
14  blender                             0x000000010932d4c7 render_startjob + 119
15  blender                             0x00000001045569a7 do_job_thread + 39
16  libsystem_pthread.dylib             0x00007fffbb74693b _pthread_body + 180
17  libsystem_pthread.dylib             0x00007fffbb746887 _pthread_body + 0
18  libsystem_pthread.dylib             0x00007fffbb74608d thread_start + 13
Process:               blender [86004]
Path:                  /Users/USER/*/blender.app/Contents/MacOS/blender
Identifier:            org.blenderfoundation.blender
Version:               2.81 (2.81 2019-09-07)
Code Type:             X86-64 (Native)
Parent Process:        zsh [84081]
Responsible:           blender [86004]
User ID:               501
Date/Time:             2019-09-07 18:10:03.096 +0200
OS Version:            Mac OS X 10.12.6 (16G1618)
Report Version:        12
Anonymous UUID:        50A54022-23B8-2012-DCDE-2106D951A58A
Sleep/Wake UUID:       2B7BED6E-9B82-44CC-B4E8-DE39C30C967B
Time Awake Since Boot: 1000000 seconds
Time Since Wake:       3600 seconds
System Integrity Protection: enabled
Crashed Thread:        0  Dispatch queue: com.apple.main-thread
Exception Type:        EXC_CRASH (SIGSEGV)
Exception Codes:       0x0000000000000000, 0x0000000000000000
Exception Note:        EXC_CORPSE_NOTIFY
Termination Signal:    Segmentation fault: 11
Termination Reason:    Namespace SIGNAL, Code 0xb
Terminating Process:   blender [86004]
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0   libsystem_c.dylib             	0x00007fffbb5863c9 __strtodg + 1659
1   libsystem_c.dylib             	0x00007fffbb58792f strtof_l + 147
2   libsystem_c.dylib             	0x00007fffbb5aeea1 __svfscanf_l + 7140
3   libsystem_c.dylib             	0x00007fffbb5b6dee vsscanf_l + 569
4   libsystem_c.dylib             	0x00007fffbb5a705a sscanf + 186
5   org.blenderfoundation.blender 	0x0000000105496c86 OpenColorIO::v1::(anonymous namespace)::LocalFileFormat::Read(std::__1::basic_istream<char, std::__1::char_traits<char> >&) const + 1494
6   org.blenderfoundation.blender 	0x000000010549fd47 OpenColorIO::v1::(anonymous namespace)::GetCachedFileAndFormat(OpenColorIO::v1::FileFormat*&, std::__1::shared_ptr<OpenColorIO::v1::CachedFile>&, std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > const&) + 2375
7   org.blenderfoundation.blender 	0x000000010549ec35 OpenColorIO::v1::BuildFileOps(std::__1::vector<std::__1::shared_ptr<OpenColorIO::v1::Op>, std::__1::allocator<std::__1::shared_ptr<OpenColorIO::v1::Op> > >&, OpenColorIO::v1::Config const&, std::__1::shared_ptr<OpenColorIO::v1::Context const> const&, OpenColorIO::v1::FileTransform const&, OpenColorIO::v1::TransformDirection) + 421
8   org.blenderfoundation.blender 	0x00000001054d52e2 OpenColorIO::v1::BuildOps(std::__1::vector<std::__1::shared_ptr<OpenColorIO::v1::Op>, std::__1::allocator<std::__1::shared_ptr<OpenColorIO::v1::Op> > >&, OpenColorIO::v1::Config const&, std::__1::shared_ptr<OpenColorIO::v1::Context const> const&, std::__1::shared_ptr<OpenColorIO::v1::Transform const> const&, OpenColorIO::v1::TransformDirection) + 514
9   org.blenderfoundation.blender 	0x00000001054a4716 OpenColorIO::v1::BuildGroupOps(std::__1::vector<std::__1::shared_ptr<OpenColorIO::v1::Op>, std::__1::allocator<std::__1::shared_ptr<OpenColorIO::v1::Op> > >&, OpenColorIO::v1::Config const&, std::__1::shared_ptr<OpenColorIO::v1::Context const> const&, OpenColorIO::v1::GroupTransform const&, OpenColorIO::v1::TransformDirection) + 150
10  org.blenderfoundation.blender 	0x00000001054d532b OpenColorIO::v1::BuildOps(std::__1::vector<std::__1::shared_ptr<OpenColorIO::v1::Op>, std::__1::allocator<std::__1::shared_ptr<OpenColorIO::v1::Op> > >&, OpenColorIO::v1::Config const&, std::__1::shared_ptr<OpenColorIO::v1::Context const> const&, std::__1::shared_ptr<OpenColorIO::v1::Transform const> const&, OpenColorIO::v1::TransformDirection) + 587
11  org.blenderfoundation.blender 	0x000000010545f0c5 OpenColorIO::v1::BuildColorSpaceOps(std::__1::vector<std::__1::shared_ptr<OpenColorIO::v1::Op>, std::__1::allocator<std::__1::shared_ptr<OpenColorIO::v1::Op> > >&, OpenColorIO::v1::Config const&, std::__1::shared_ptr<OpenColorIO::v1::Context const> const&, std::__1::shared_ptr<OpenColorIO::v1::ColorSpace const> const&, std::__1::shared_ptr<OpenColorIO::v1::ColorSpace const> const&) + 1173
12  org.blenderfoundation.blender 	0x000000010545eb58 OpenColorIO::v1::BuildColorSpaceOps(std::__1::vector<std::__1::shared_ptr<OpenColorIO::v1::Op>, std::__1::allocator<std::__1::shared_ptr<OpenColorIO::v1::Op> > >&, OpenColorIO::v1::Config const&, std::__1::shared_ptr<OpenColorIO::v1::Context const> const&, OpenColorIO::v1::ColorSpaceTransform const&, OpenColorIO::v1::TransformDirection) + 344
13  org.blenderfoundation.blender 	0x00000001054d520b OpenColorIO::v1::BuildOps(std::__1::vector<std::__1::shared_ptr<OpenColorIO::v1::Op>, std::__1::allocator<std::__1::shared_ptr<OpenColorIO::v1::Op> > >&, OpenColorIO::v1::Config const&, std::__1::shared_ptr<OpenColorIO::v1::Context const> const&, std::__1::shared_ptr<OpenColorIO::v1::Transform const> const&, OpenColorIO::v1::TransformDirection) + 299
14  org.blenderfoundation.blender 	0x00000001054a4716 OpenColorIO::v1::BuildGroupOps(std::__1::vector<std::__1::shared_ptr<OpenColorIO::v1::Op>, std::__1::allocator<std::__1::shared_ptr<OpenColorIO::v1::Op> > >&, OpenColorIO::v1::Config const&, std::__1::shared_ptr<OpenColorIO::v1::Context const> const&, OpenColorIO::v1::GroupTransform const&, OpenColorIO::v1::TransformDirection) + 150
15  org.blenderfoundation.blender 	0x00000001054d532b OpenColorIO::v1::BuildOps(std::__1::vector<std::__1::shared_ptr<OpenColorIO::v1::Op>, std::__1::allocator<std::__1::shared_ptr<OpenColorIO::v1::Op> > >&, OpenColorIO::v1::Config const&, std::__1::shared_ptr<OpenColorIO::v1::Context const> const&, std::__1::shared_ptr<OpenColorIO::v1::Transform const> const&, OpenColorIO::v1::TransformDirection) + 587
16  org.blenderfoundation.blender 	0x000000010545f0c5 OpenColorIO::v1::BuildColorSpaceOps(std::__1::vector<std::__1::shared_ptr<OpenColorIO::v1::Op>, std::__1::allocator<std::__1::shared_ptr<OpenColorIO::v1::Op> > >&, OpenColorIO::v1::Config const&, std::__1::shared_ptr<OpenColorIO::v1::Context const> const&, std::__1::shared_ptr<OpenColorIO::v1::ColorSpace const> const&, std::__1::shared_ptr<OpenColorIO::v1::ColorSpace const> const&) + 1173
17  org.blenderfoundation.blender 	0x0000000105474973 OpenColorIO::v1::BuildDisplayOps(std::__1::vector<std::__1::shared_ptr<OpenColorIO::v1::Op>, std::__1::allocator<std::__1::shared_ptr<OpenColorIO::v1::Op> > >&, OpenColorIO::v1::Config const&, std::__1::shared_ptr<OpenColorIO::v1::Context const> const&, OpenColorIO::v1::DisplayTransform const&, OpenColorIO::v1::TransformDirection) + 2947
18  org.blenderfoundation.blender 	0x00000001054d5254 OpenColorIO::v1::BuildOps(std::__1::vector<std::__1::shared_ptr<OpenColorIO::v1::Op>, std::__1::allocator<std::__1::shared_ptr<OpenColorIO::v1::Op> > >&, OpenColorIO::v1::Config const&, std::__1::shared_ptr<OpenColorIO::v1::Context const> const&, std::__1::shared_ptr<OpenColorIO::v1::Transform const> const&, OpenColorIO::v1::TransformDirection) + 372
19  org.blenderfoundation.blender 	0x0000000105468c7a OpenColorIO::v1::Config::getProcessor(std::__1::shared_ptr<OpenColorIO::v1::Transform const> const&, OpenColorIO::v1::TransformDirection) const + 90
20  org.blenderfoundation.blender 	0x0000000105468c13 OpenColorIO::v1::Config::getProcessor(std::__1::shared_ptr<OpenColorIO::v1::Transform const> const&) const + 19
21  org.blenderfoundation.blender 	0x000000010438b919 OCIOImpl::configGetProcessor(OCIO_ConstConfigRcPtr__**, OCIO_ConstTransformRcPtr__**) + 73
22  org.blenderfoundation.blender 	0x0000000104359d2b create_display_buffer_processor + 459
23  org.blenderfoundation.blender 	0x000000010435a30f IMB_colormanagement_setup_glsl_draw_from_space + 959
24  org.blenderfoundation.blender 	0x000000010812699b ED_draw_imbuf_clipping + 331
25  org.blenderfoundation.blender 	0x0000000108126ca1 ED_draw_imbuf_ctx_clipping + 129
26  org.blenderfoundation.blender 	0x000000010807a4ec draw_image_buffer + 508
27  org.blenderfoundation.blender 	0x0000000108079d69 draw_image_main + 457
28  org.blenderfoundation.blender 	0x00000001080841bc image_main_region_draw + 732
29  org.blenderfoundation.blender 	0x000000010811ebd2 ED_region_do_draw + 370
30  org.blenderfoundation.blender 	0x00000001045423c6 wm_draw_update + 1878
31  org.blenderfoundation.blender 	0x000000010453ffa0 WM_main + 48
32  org.blenderfoundation.blender 	0x0000000104057d4f main + 927
33  libdyld.dylib                 	0x00007fffbb52d235 start + 1
Thread 1:
0   libsystem_kernel.dylib        	0x00007fffbb65bbf2 __psynch_cvwait + 10
1   libsystem_pthread.dylib       	0x00007fffbb7477fa _pthread_cond_wait + 712
2   libc++.1.dylib                	0x00007fffba0714cd std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&) + 47
3   org.blenderfoundation.blender 	0x0000000105416bd3 IlmThread_2_3::Semaphore::wait() + 147
4   org.blenderfoundation.blender 	0x0000000105414132 IlmThread_2_3::(anonymous namespace)::DefaultWorkerThread::run() + 66
5   org.blenderfoundation.blender 	0x0000000105416627 void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_3::Thread::*)(), IlmThread_2_3::Thread*> >(void*) + 663
7   libsystem_pthread.dylib       	0x00007fffbb746887 _pthread_start + 286
Thread 2:
Thread 3:
Thread 4:
Thread 5:
Thread 6:
Thread 7:
Thread 8:
Thread 9:
0   libsystem_kernel.dylib        	0x00007fffbb65c44e __workq_kernreturn + 10
1   libsystem_pthread.dylib       	0x00007fffbb746621 _pthread_wqthread + 1426
2   libsystem_pthread.dylib       	0x00007fffbb74607d start_wqthread + 13
Thread 10:: com.apple.audio.IOThread.client
0   libsystem_kernel.dylib        	0x00007fffbb65434a mach_msg_trap + 10
1   libsystem_kernel.dylib        	0x00007fffbb653797 mach_msg + 55
2   com.apple.audio.CoreAudio     	0x00007fffa5897935 HALB_MachPort::SendMessageWithReply(unsigned int, unsigned int, unsigned int, unsigned int, mach_msg_header_t*, bool, unsigned int) + 127
3   com.apple.audio.CoreAudio     	0x00007fffa58978a6 HALB_MachPort::SendSimpleMessageWithSimpleReply(unsigned int, unsigned int, int, int&, bool, unsigned int) + 42
4   com.apple.audio.CoreAudio     	0x00007fffa58948d0 HALC_ProxyIOContext::IOWorkLoop() + 1196
5   com.apple.audio.CoreAudio     	0x00007fffa5894264 HALC_ProxyIOContext::IOThreadEntry(void*) + 128
6   com.apple.audio.CoreAudio     	0x00007fffa5893fa3 HALB_IOThread::Entry(void*) + 75
7   libsystem_pthread.dylib       	0x00007fffbb74693b _pthread_body + 180
8   libsystem_pthread.dylib       	0x00007fffbb746887 _pthread_start + 286
9   libsystem_pthread.dylib       	0x00007fffbb74608d thread_start + 13
Thread 11:
Thread 12:
2   org.blenderfoundation.blender 	0x000000010431e6ec task_scheduler_thread_run + 684
3   libsystem_pthread.dylib       	0x00007fffbb74693b _pthread_body + 180
4   libsystem_pthread.dylib       	0x00007fffbb746887 _pthread_start + 286
5   libsystem_pthread.dylib       	0x00007fffbb74608d thread_start + 13
Thread 13:
Thread 14:
Thread 15:
Thread 16:
Thread 17:
Thread 18:
Thread 19:: com.apple.NSEventThread
2   com.apple.CoreFoundation      	0x00007fffa5d2e354 __CFRunLoopServiceMachPort + 212
3   com.apple.CoreFoundation      	0x00007fffa5d2d7e1 __CFRunLoopRun + 1361
4   com.apple.CoreFoundation      	0x00007fffa5d2d034 CFRunLoopRunSpecific + 420
5   com.apple.AppKit              	0x00007fffa396ff02 _NSEventThread + 205
Thread 20:
Thread 21:
0   ???                           	0x0000700006c06350 0 + 123145415582544
Thread 22:
Thread 23:
Thread 24:
Thread 25:
Thread 26:
Thread 0 crashed with X86 Thread State (64-bit):
  rax: 0x00007fed9c051e62  rbx: 0x00007fed9c051e01  rcx: 0x0000000000000009  rdx: 0x0000000000000005
  rdi: 0x0000000000000001  rsi: 0x0000000000000000  rbp: 0x00007fff5bcef250  rsp: 0x00007fff5bcef110
   r8: 0x0000000000000001   r9: 0x0000000000000005  r10: 0x0000000000000006  r11: 0x00007fed9c051e67
  r12: 0x00007fed9c051e62  r13: 0x00007fed9c051e67  r14: 0x0000000000000006  r15: 0x0000000000000000
  rip: 0x00007fffbb5863c9  rfl: 0x0000000000000246  cr2: 0x0000000101ffa000
Logical CPU:     0
Error Code:      0x00000000
Trap Number:     222
Germano Cavalcante (mano-wii) changed the task status from Confirmed to Needs Information from Developers.Feb 7 2020, 2:11 PM
While the file in the description somehow causes a sudden rise in memory (before I force quit it), the "T61853_part1.blend" renders fine on
rB82c51d0edbab45f014b4d0b4c0a96c000c46e232
Operating system: Darwin-18.7.0-x86_64-i386-64bit 64 Bits
Graphics card: Intel(R) HD Graphics 6000 Intel Inc. 4.1 INTEL-12.10.12
It could be worth trying on newer builds.
This is now fairly old, confusing (several issues apparently?), includes some mere memory running out, and has not been reconfirmed with any recent build (code in those areas has changed a lot). So thanks for the report, but will close it now, please create a new one with up-to-date information if you still experience the problem.
