Loading times of files that link in external data has become inacceptable
Operating system: Windows 10, latest SP
Graphics card: Quadro K4000
Broken: 358e07f447e9ed7f87f419e8d027e73c97c00077
Worked: f3e9dff03d9bde0d3002eecb1d51dd0baabbb285
The mentioned commit tries to reduce the memory usage when loading linked data. While this may work fine, loading times of such files increased for us in the studio dramatically. As an example, loading time of a file that only links from a single library increased from 2 seconds to roughly two minutes. I am loading both the file and the linked data from a network drive which is write protected. Other files have not suffered that much, but also open way slower than before.
Can't provide a blend as these projects are confidential. The only thing I can post so far is a screenshot of the outliner in 'blend file' mode:
I tested .blend load time on a Spring production file on my Linux desktop. Here the change actually improved load time significantly.
BeforeAfter
Local SSD08.28s5.04s
NFS Network19.18s14.04s
This problem may be Windows specific, I've run into extremely slow random access on network drivers there before. Using std::ifstream and seeking instead of mmap helped in that case, apparently due to memory mapping not always going through the system file cache. This might be the same kind of issue.
@Campbell Barton (campbellbarton), maybe we can disable this change on Windows for now, and then investigate how to fix it later? The Linux file load time is actually a great improvement I didn't expect from this change.
Campbell Barton (campbellbarton) changed the task status from Unknown Status to Resolved.Feb 22 2019, 11:37 PM
I'll disable this for windows - for now, this could be tuned by only applying to blocks over a certain size - however if seeking is very slow, this may still be slower.
In my own tests on a HDD (not an SSD) I saw speedups similar to Brecht's, so I didn't think it necessary to tweak.
Looks like this is a duplicate for T61880, re-enabling read on demand for WIN32.
