Mesh Deform Modifier does not work in some scenarios (invalid raport casued by flipped normals)
Operating system: Linux Ubuntu 18.04
Graphics card: Intel iGPU HD4600
Broken:
blender-2.80-9a8a5676da82-linux-glibc224-x86_64
2.79b
Mesh Deform Modifier does not work in some scenarios:
  1. If control mesh is extruded from circle object with fill type: Nothing,
and faces* of extruded circle are created manually
  1. If control mesh is extruded from separated vertex/edge loop of existing object,
and faces* of extruded loop are created manually
  1. If control mesh is extruded from separated face of existing object
*faces that closes mesh, to make it "watertight"
Video:
https://drive.google.com/open?id=1SOwgtyrwAMVP47ervIgNwOVuepoklMVE
Blendfile used for video:
Exact steps for others to reproduce the error:
  1. open blender
  2. Shift + A -> Mesh -> Circle
  3. Set radius to 1.5m
  4. Set Fill Type to Nothing
  5. Set Location Z to -1.5m
  6. Click Select Circle
  7. go to edit mode
  8. A to select all vertices
  9. E + Z + 3 to extrude vertex loop 3m along Z axis
  10. F to make face on top vertex loop
  11. Alt + LMB to select bottom vertex loop
  12. F to make face on bottom vertex loop
  13. Go to object mode
  14. Select object named Circle
  15. Go to Object tab -> Viewport Display
  16. Set Display As to Wire
  17. Select object named Cube
  18. Go to Modifiers tab
  19. Add Mesh Deform Modifier
  20. As contorl object of Deform Modifier set object named Circle
  21. Click Bind button
  22. Click select object named Circle
  23. Go to edit mode
  24. ALT + LMB to select top vertex loop
  25. S + 5 to scale vertex loop by factor of 5
Piotr Kudzin (sng84) renamed this task from Mesh Deform Modifier does not work in some scenarios to Mesh Deform Modifier does not work in some scenarios (invalid raport casued by flipped normals).Feb 25 2019, 10:51 PM
Piotr Kudzin (sng84) changed the task status from Unknown Status to Archived.
