Blender hang on ALT-A
The attached blend file causes Blender to go "not responding" when I do ALT-A.
= Blender 2.43 System Information =
Platform: win32
Python:
- Version: 2.4.2 (#46, Nov 17 2005, 20:11:16) [MSC v.1200 32 bit (Intel)]
- Paths:
C:\Program Files\Blender Foundation\Blender
C:\Program Files\Blender Foundation\Blender\python24.zip
.\DLLs
.\lib
.\lib\plat-win
.\lib\lib-tk
C:\PROGRA~1\BLENDE~1\Blender
C:\Documents and Settings\martine\Application Data\Blender Foundation\Blender\.blender\scripts
C:\Documents and Settings\martine\Application Data\Blender Foundation\Blender\.blender\scripts\bpymodules
- Directories:
Blender home dir:
Default dir for scripts:
Default "bpydata/" data dir for scripts:
C:\Documents and Settings\martine\Application Data\Blender Foundation\Blender\.blender\scripts\bpydata
User defined dir for scripts:
<NOTICE> -- not found
Data dir "bpydata/" inside user defined dir:
Default config data "bpydata/config/" dir:
C:\Documents and Settings\martine\Application Data\Blender Foundation\Blender\.blender\scripts\bpydata\config
- Modules: all basic ones were found.
OpenGL:
- Renderer: Intel 915GM
- Vendor: Intel
- Version: 1.4.0 - Build 4.14.10.4410
- Extensions:
GL_ARB_depth_texture GL_ARB_fragment_program GL_ARB_multitexture
GL_ARB_point_parameters GL_ARB_shadow GL_ARB_texture_border_clamp
GL_ARB_texture_compression GL_ARB_texture_cube_map
GL_ARB_texture_env_add GL_ARB_texture_env_combine
GL_ARB_texture_env_dot3 GL_ARB_texture_env_crossbar
GL_ARB_transpose_matrix GL_ARB_vertex_buffer_object
GL_ARB_vertex_program GL_ARB_window_pos GL_EXT_abgr GL_EXT_bgra
GL_EXT_blend_color GL_EXT_blend_func_separate GL_EXT_blend_minmax
GL_EXT_blend_subtract GL_EXT_clip_volume_hint
GL_EXT_compiled_vertex_array GL_EXT_cull_vertex
GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_multi_draw_arrays
GL_EXT_packed_pixels GL_EXT_rescale_normal GL_EXT_secondary_color
GL_EXT_separate_specular_color GL_EXT_shadow_funcs
GL_EXT_stencil_two_side GL_EXT_stencil_wrap
GL_EXT_texture_compression_s3tc GL_EXT_texture_env_add
GL_EXT_texture_env_combine GL_EXT_texture_filter_anisotropic
GL_EXT_texture3D GL_3DFX_texture_compression_FXT1
GL_IBM_texture_mirrored_repeat GL_NV_blend_square
GL_NV_texgen_reflection GL_SGIS_generate_mipmap GL_WIN_swap_hint
- Simplistic almost useless benchmark:
Redrawing all areas 10 times took 0.3308 seconds.
(*) Found 2 notices, documented in the text above.
Logged In: YES
user_id=5634
Some more information on the system (do you need any more?):
Processor Intel(R) Pentium(R) M processor 1.73GHz
Processor Speed 1.69 GHz
Memory (RAM) 1024 MB
Operating System Microsoft Windows XP Professional
Operating System Version 5.1.2600
Logged In: YES
user_id=5634
It renders quite happily from the command prompt.
Logged In: YES
user_id=103
Apparently you have on-board intel graphics, which is well known for poor opengl support. I cannot judge if the crash is related to that. You could by tweaking opengl settings (disable all acceleration for example)
Tests with your file in OSX go fine.
Logged In: YES
user_id=5634
The blend works for me on my other box, which has an nVidia card, so I suppose Ton must be right.
Logged In: YES
user_id=103
Too bad to hear this... intel graphics is giving us unpredictable issues all the time.
The only thing we can do is hope for a developer who likes to suffer Intel graphics, and create bypasses or fixes for the most common errors...
Logged In: YES
user_id=5634
I turned off all hardware acceleration and 'write combining', rebooted (to apply the settings), loaded my blend and did ALT-A... no problems.
I turned hardware acceleration back to full, re-enabled 'write combining' etc etc and it hung again as previously.
So it is something to do with the acceleration.
Matt Ebb (broken) changed the task status from Unknown Status to Unknown Status.Mar 26 2010, 6:37 AM
