eevee not rendering height map
Windows 10
Radeon Vega 64
Broken: 2.80, a0f2923fd821
Rendering a flat plan with a PBR texture w/height map the render doesn't use it. rendering from the viewport you can see the difference.
Normal render
Viewport render (While in camera)
Blend file
Jacques Lucke (JacquesLucke) lowered the priority of this task from 90 to 30.Mar 11 2019, 10:33 AM
You forgot to pack the texture into the .blend file (I only see a pink plane).
File -> External Data -> Pack All into .blend.
Here is the .blend with the texture.
Brecht Van Lommel (brecht) changed the task status from Unknown Status to Unknown Status.Mar 11 2019, 5:28 PM
In the subdivision surface modifier, you need to increase the render levels to match the viewport levels.
