Operating system: windows 10
Graphics card:Nvidia Geforce GTX 1060
Broken: 2.80, 1df6a98b176f, blender2.8, 2019-03-05
(example: 2.79b release)
Worked: 2.79b
confirm on release action in shortcut settings don't work.
setup a shortcut for "move" action with a specified fixed delta to a single keyboard key stroke and activate "confirm on release".
When you click the shortcut, the selection should be moved by the delta and confirmed, but instead moving the mouse will keep on moving the selection. Confirm didn't work.
This setup used to work as intended in 2.79
