Skeleton rig with keyframes prevents selection of Shader Nodetree channels in Dope Sheet and Graph Editor
Closed, ResolvedPublicBUG
Broken: 2.80-6fd11a21f5c5-win64
Worked: 2.79
If I have a skeletal rig posed with keyframes, and I want to select a channel of a Shader Nodetree, it's impossible.
For some reason clicking on the channel or the keyframes fails to activate the fcurve, so it's impossible to add modifiers in the graph editor.
It sounds bizarre, but I've spent over 2 hours refining this bug to its core, and that appears to be its simplest description.
Please see attached blend example below.
To test, try selecting any of the shader tree property channels, observe that the channels cannot be selected. Now delete rig and try again. Notice that the channels are now selectable.
Pushing the rig action into a strip or hiding it also allows the shader channels to be selected.
Richard Antalik (ISS) changed the subtype of this task from "Report" to "Bug".
This is likely a nasty side-effect of the selection synchronisation between channels and bones. I've added this issue to my list of Weak Areas of the Animation System.
