VSE doesn't work with left click select
Operating system:
Graphics card:
Broken:
(example: 2.79b release)
can not select items in the tracks with left click select enabled. If you stack items in the VSE, you can not select those items with left click enabled.
William Reynish (billreynish) lowered the priority of this task from 90 to 30.Mar 12 2019, 5:52 PM
Please fill out the form properly.
  • Fill out System Information
  • Fill out Blender Version
  • Fill out Exact steps for others to reproduce the error
Windows 10 64 bit, i5 3.10 ghz (applies to all platforms)
Blender 2.80 beta build date 2019-03-12 01:08
Hash 6b39dc7672eb
Branch blender2.7
If you stack items on tracks in the VSE and have "left click" selected in options, you can not select the items in the VSE.
@Herb Brown (MusicAMG) I cannot reproduce the issue. Selecting clips in the VSE works normally.
Try doing File > Load Factory Defaults to clear any custom keymap or other change you may have done.
Bastien Montagne (mont29) changed the task status from Unknown Status to Unknown Status.Mar 19 2019, 10:17 AM
