Mesh objects are invisible if you open this file with the "load UI" option unchecked
Operating system: Linux Mint 18.3 Cinnamon 64-bit
Graphics card: Nvidia Geforce 760
Broken:936014ea8c74
uncheck "Load UI" in preferences, and save configuration.
Close Blender, open it again and open the attached file.
Mesh objects are invisible in the "layout" workspace
however, they are selectable, and you can see the shape if you select them.
they are visible again if you activate the "show the whole scene transparent" option
edwin hernandez (juanito49) renamed this task from Objects are invisible if you open this file with "load UI" option is unchecked to Mesh objects are invisible if you open this file with the "load UI" option unchecked.Mar 13 2019, 1:29 AM
edwin hernandez (juanito49) created this task.
edwin hernandez (juanito49) updated the task description. (Show Details)
Jacques Lucke (JacquesLucke) lowered the priority of this task from 90 to 50.Mar 13 2019, 11:52 AM
I can reproduce the issue in this file.
Can you reproduce the problem in a new file? If yes, how?
No, I couldn't, however, I have other files with the same behavior. these are assignments from students.
despite I couldn't reproduce this error, note that if you open these files with the "load UI" checked, all of them appear in workspace "layout" with "lookdev" and "make the whole scene transparent" activated.
I hope this helps you
Jacques Lucke (JacquesLucke) raised the priority of this task from 50 to 90.Mar 13 2019, 4:28 PM
Sebastian Parborg (zeddb) changed the task status from Unknown Status to Archived.Mar 13 2019, 4:51 PM
Sebastian Parborg (zeddb) claimed this task.
This is not a bug. If you change to solid mode with Load UI, they also become invisible as the color alpha for them in Viewport Display under material settings has been set to 0.
