Object with "Viewport display" - "Display as" "Box" and "Wireframe" are not displays in render (EEVEE)
Closed, DuplicatePublic
Operating system: ubuntu 18.04
Graphics card: GTX 1070 driver: 390.116
Broken: March 13, 01:20:20 - bf9904ec8018
Worked: Works in Cycles.
Object with "Viewport display" - "Display as" "Box" and "Wireframe" are not displays in EEVEE render and renders in Cycles
This setting only for Viewport display, not render setting, isn't it?
Meanwhile, Solid works properly. Then Display as set as Solid, this works as for solid mode (not displays texture then color set to texture) and in render (texture appears)
  1. Open test file or in any mesh object "Viewport display" - "Display as" set to "Box" or "Wireframe"
  1. Render in Cycles - Object renders. Render in EEVEE - object is hidden.
Maybe related: https://developer.blender.org/T62548
I confirm that if the display as is set to box or wireframe, then it doesn't render in Eevee and Lookdev, but in Cycles the object does show up.
I'll merge this into T62548 as I think that the root cause is the same.
