Black faces in solid view
Closed, ResolvedPublicKNOWN ISSUE
See attached file.. if you rotate the view, you'll notice the left half of the building (mirrored from the right half) has black faces. They are gone if it is either 1) selected, or 2) size is applied (after making single-user).
Logged In: YES
user_id=103
For me the right half is mirrored (negative scaled), and nothing shows in black... it draws as you would expect.
Now i cannot imagine this is opengl error? Your nvidia always functioned well.
Logged In: YES
user_id=980
Well, it's surprising for me too, however, here's a screenshot (attached).
Logged In: YES
user_id=103
Attached one screenie too.
You're now a bit on your own, what does this come from? How to get the error, how to get it away? I can ask another linuxer to load and compare.
Logged In: YES
user_id=980
Oh well, this is strange. I had *exactly* the same problem in (do not laugh) Doom 3, because the Doom3 Engine uses exactly the same trick to display the other half of (human) faces and other symmetrical objects.. there were black faces too, and I upgraded the drivers (or downgraded?), and it's fixed there.
I should probably try another driver version then.. if that only weren't such a pain in the ass on linux. :)
Logged In: YES
user_id=103
Well, the left part is not even negative scaled!
(moved report to ogl tracker)
Logged In: YES
user_id=980
Oh, you're right. So the mirrored object actually gets displayed correctly while the original doesn't (EXCEPT if it is selected!)...
Matt Ebb (broken) changed the task status from Unknown Status to Unknown Status.Mar 26 2010, 6:37 AM
Diffusion changed the task status from Unknown Status to Resolved.Nov 8 2014, 2:40 PM
Closed by commit rP6db25aa41c9d.
