Append shortcut work fine only in specify area of Blender window.
Operating system: Windows-10-10.0.15063 64 Bits
Graphics card: Quadro K2200/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 416.78
Broken: version: 2.80 (sub 51), branch: blender2.7, commit date: 2019-03-25 00:55, hash: rB07f6be87a97e
When I put shift + F1 shortcut for example in 3D viewport, Blender switch me to File browser. When I use this shortcut above this section it works correct.
When I hit Shift+F1 on "D" area it works fine. On A,B,C switch me to file browser.
Brecht Van Lommel (brecht) changed the task status from Unknown Status to Resolved.Mar 25 2019, 4:01 PM
Shift+F1 is no longer the shortcut for link/append, it is the shortcut for opening the file browser.
You can use the F4 menu for quick access to link/append.
T55194: Shortcut Keys Changed in 2.8x
Brecht Van Lommel (brecht) changed the task status from Resolved to Unknown Status.Mar 25 2019, 4:11 PM
OK I understood now, I had shortcuts blender27 enabled. So not all blender27's shortcuts work correctly in 2.8?
I've fixed it in the 2.7 keymap now.
