It is not applied the scale object that parented with armature (weight painted).
Mac OS Mojave
Broken 2.80 Beta
Work 2.79
Add a Cube and a single Bone.
Set parent to armature with automatic weight paints.
Scale up them at the same time.
Apply scale.
Armature is applied scale.
But object(Cube) is not applied scale
and object becomes the size before scales up.
Kihaku Gisui (Kihaku_Gisui) renamed this task from When I try to apply the scale object that parented with armature, It is not apply the object scale. to When I try to apply the scale object that parented with armature, It is not applied the object scale..Apr 8 2019, 9:28 AM
Kihaku Gisui (Kihaku_Gisui) created this task.
Kihaku Gisui (Kihaku_Gisui) updated the task description. (Show Details)
Kihaku Gisui (Kihaku_Gisui) renamed this task from When I try to apply the scale object that parented with armature, It is not applied the object scale. to It is not applied the object scale when I try to apply the scale object that parented with armature (weight painted)..Apr 8 2019, 9:39 AM
Kihaku Gisui (Kihaku_Gisui) renamed this task from It is not applied the object scale when I try to apply the scale object that parented with armature (weight painted). to It is not applied the scale object that parented with armature (weight painted)..Apr 8 2019, 9:44 AM
Philipp Oeser (lichtwerk) changed the task status from Duplicate to Unknown Status.Apr 8 2019, 4:31 PM
Not 100% sure this is really on the same page as T55494, so will reopen for now...
Philipp Oeser (lichtwerk) lowered the priority of this task from 90 to 50.
@Sergey Sharybin (sergey): will assign to you (because of similarity to T55494)
Sergey Sharybin (sergey) changed the task status from Unknown Status to Resolved.Jun 5 2019, 3:03 PM
This should be resolved by rB26d4a2a51694.
If it's not, please make a new report.
