Windows 10 Pro X64
AMD RADEON RX570
Broken: blender-2.80-009dbc2bc9fb-win64
- Animation playback problem - Animation Playback doesn't sync in two main window with defferent view layers, but sub window with the same view layer is ok.
- EditMode problem - If you select an armature and enter editmode, and the armature disappears form other view layers. But, in pose mode, everything is ok. Any changes in pose mode correctly update other view layer's rendering.
Open the attached *.blend file, and you will see 3 windows - main window, sub window with the same view layer, another main window with other view layer.
Enter edit mode with armature, and it disappear from 3rd window.
But enter pose mode and make any changes, that correctly updates other windows.
Just playback animation.
