Blender crashes when deleting particle hair keys
Operating system: Ubuntu 18:04 64 bit
Graphics card: Nvidia 1070 8gb
Broken: (example: 2.80, 14884cda1ff5, master, commit date: 2019-04-13 18:58
Worked:
  1. Open the provided bug1.blend file.
  2. if not on particle edit navigate to particle edit of the sphere
  3. try deleting selected particle keys via shortcut - press x and select "key" from the menu. (Blender crashes)
attached blender file, crash file and system info
Files:
Janez Rupar (fakk2) renamed this task from Blender crashes to Blender crashes when deleting particle hair keys.Apr 14 2019, 1:27 PM
Backtrace:
Thread 1 "blender" received signal SIGSEGV, Segmentation fault.
0x000055555858acbd in psys_face_mat (ob=0x7fffc5fa8208, mesh=0x0, pa=0x7fffc9cad008, mat=0x7fffffffd3f0, orco=1)
    at /home/zed/prog/blender/source/blender/blenkernel/intern/particle.c:2984
2984		if (i == -1 || i >= mesh->totface) { unit_m4(mat); return; }
(gdb) bt
#0  0x000055555858acbd in psys_face_mat (ob=0x7fffc5fa8208, mesh=0x0, pa=0x7fffc9cad008, mat=0x7fffffffd3f0, orco=1)
#1  0x000055555858b04b in psys_mat_hair_to_orco (ob=0x7fffc5fa8208, mesh=0x0, from=1, pa=0x7fffc9cad008, hairmat=0x7fffffffd3f0)
    at /home/zed/prog/blender/source/blender/blenkernel/intern/particle.c:3027
#2  0x0000555557af7ed4 in PE_mirror_particle (ob=0x7fffc5fa8208, mesh=0x0, psys=0x7fffc9cd7408, pa=0x7fffc9cad008, mpa=0x7fffc9cad7d8)
    at /home/zed/prog/blender/source/blender/editors/physics/particle_edit.c:997
#3  0x0000555557afd656 in remove_tagged_keys (ob=0x7fffc5fa8208, psys=0x7fffc9cd7408)
    at /home/zed/prog/blender/source/blender/editors/physics/particle_edit.c:2658
#4  0x0000555557afedd6 in delete_exec (C=0x7fffe3858188, op=0x7fffc5fbe208) at /home/zed/prog/blender/source/blender/editors/physics/particle_edit.c:3072
#5  0x000055555752fc52 in WM_menu_invoke_ex (C=0x7fffe3858188, op=0x7fffc5fbe208, opcontext=1)
    at /home/zed/prog/blender/source/blender/windowmanager/intern/wm_operators.c:741
#6  0x000055555752fda3 in WM_menu_invoke (C=0x7fffe3858188, op=0x7fffc5fbe208, UNUSED_event=0x7fffdd565c88)
    at /home/zed/prog/blender/source/blender/windowmanager/intern/wm_operators.c:760
#7  0x0000555557512b86 in wm_operator_invoke (C=0x7fffe3858188, ot=0x7fffde5875c8, event=0x7fffdd565c88, properties=0x7fffffffd950, reports=0x0,
    poll_only=false, use_last_properties=true) at /home/zed/prog/blender/source/blender/windowmanager/intern/wm_event_system.c:1371
#8  0x0000555557513351 in wm_operator_call_internal (C=0x7fffe3858188, ot=0x7fffde5875c8, properties=0x7fffffffd950, reports=0x0, context=1, poll_only=false,
    event=0x7fffdd565c88) at /home/zed/prog/blender/source/blender/windowmanager/intern/wm_event_system.c:1582
#9  0x0000555557513574 in WM_operator_name_call_ptr (C=0x7fffe3858188, ot=0x7fffde5875c8, context=1, properties=0x7fffffffd950)
    at /home/zed/prog/blender/source/blender/windowmanager/intern/wm_event_system.c:1630
#10 0x000055555785913d in ui_apply_but_funcs_after (C=0x7fffe3858188) at /home/zed/prog/blender/source/blender/editors/interface/interface_handlers.c:782
#11 0x0000555557871719 in ui_popup_handler (C=0x7fffe3858188, event=0x7fffc5c37708, userdata=0x7fffc9cb8748)
    at /home/zed/prog/blender/source/blender/editors/interface/interface_handlers.c:10130
#12 0x000055555751092b in wm_handler_ui_call (C=0x7fffe3858188, handler=0x7fffd302db68, event=0x7fffc5c37708, always_pass=0)
    at /home/zed/prog/blender/source/blender/windowmanager/intern/wm_event_system.c:598
#13 0x0000555557515a76 in wm_handlers_do_intern (C=0x7fffe3858188, event=0x7fffc5c37708, handlers=0x7fffdd42bd98)
    at /home/zed/prog/blender/source/blender/windowmanager/intern/wm_event_system.c:2551
#14 0x000055555751644d in wm_handlers_do (C=0x7fffe3858188, event=0x7fffc5c37708, handlers=0x7fffdd42bd98)
    at /home/zed/prog/blender/source/blender/windowmanager/intern/wm_event_system.c:2784
#15 0x0000555557517681 in wm_event_do_handlers (C=0x7fffe3858188) at /home/zed/prog/blender/source/blender/windowmanager/intern/wm_event_system.c:3145
#16 0x000055555750becf in WM_main (C=0x7fffe3858188) at /home/zed/prog/blender/source/blender/windowmanager/intern/wm.c:421
#17 0x000055555750657f in main (argc=1, argv=0x7fffffffe078) at /home/zed/prog/blender/source/creator/creator.c:503
