Operating system: Windows 7, 64bit
Graphics card:
Broken: (example: 2.80, edc1b0167518)
Worked: (optional) 2.79b
I'm using Blender as a 3D live view controlled from an external application (see https://developer.blender.org/T62051 for more details).
I just noticed that, compared to Blender 2.79, some operations are up to 20x slower in 2.80!
Here is an example:
import time
import bpy
def add_cylinder():
window = bpy.context.window_manager.windows[0]
ctx = {'window': window, 'screen': window.screen}
start = time.clock()
bpy.ops.mesh.primitive_cylinder_add(
ctx,
radius=1, depth=1,
location=(1.5, 0.0, 1),
enter_editmode=False,
print(time.clock() - start)
print()
return 1
bpy.app.timers.register(add_cylinder)Interestingly, these operations are only slow when I have loaded my 3D model (stats: Verts ~120.000, Faces ~200.000, Tris: ~250.000, Objects: ~1000).
When I run this example in an empty Blender file with 2.80 it is always fast (max 4ms, usually faster). In Blender 2.79 (code attached) with my model loaded it performs still very good (4ms to 8ms). However, running this on 2.80 with my model loaded it takes 60 to 85 ms!
I guess this is related to the new renderer. For a workaround it would be perfectly fine if I could disable rendering during my timer callbacks (if that helps), but I couldn't find anything in the API docs.
