Graphics card: GeForce GT 1030/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 385.12
Broken: version: 2.80 (sub 58), branch: master, commit date: 2019-04-23 12:31, hash: rB5a144c797a3b
When using Custom Split Normal Data (or just custom vertex normal) with mirror modifier, normal vectors are not mirrored properly.
- In default Cube, Object Data, Normals, enable Auto Smooth
- Move base cube in edit mode off the origin center
- Select all and go to Mesh, Normals, Set From Faces
- Select top face and repeat Set From Faces
- Add mirror modifier to the object
Results are different, not mirrored normals.
[Based on the attached .blend file (as simple as possible)]
