Set change frame and set cursor to LeftMouse click as Default
Closed, ArchivedPublicDESIGN
Should Cursor set and Change frame be changed to left click as default.Having Cursor set and Change frame as Right click is unintuitive. It remove the option for menus which are normally on the Right mouse button and selecting and moving should be consistent.
Eitan Traurig (EitanSomething) lowered the priority of this task from 90 to Low.Apr 24 2019, 6:01 AM
Eitan Traurig (EitanSomething) edited a custom field.
Eitan Traurig (EitanSomething) updated the task description. (Show Details)
Eitan Traurig (EitanSomething) renamed this task from Change Mouse select ton left on to set change frame and set cursor to LeftMouse click as Default.Apr 24 2019, 6:05 AM
Eitan Traurig (EitanSomething) renamed this task from set change frame and set cursor to LeftMouse click as Default to Set change frame and set cursor to LeftMouse click as Default.
William Reynish (billreynish) changed the task status from Unknown Status to Unknown Status.Apr 24 2019, 1:52 PM
This is covered by the todo item T63193
