Cycles 2.8 Dispersion, Caustics For Realistic Diamond For Product Design.
Graphics card: GeForce GTX 1050 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 419.35
Broken: version: 2.80 (sub 59), branch: master, commit date: 2019-04-26 06:00, hash: rB513b71c89ad0
Hello ,
Could please add develop in Blender 2.8 Cycles Dispersion, Caustics For Realistic Diamond For Product Design ?
Thank you.
Marco (nacioss) changed the task status from Unknown Status to Archived.Apr 28 2019, 8:47 PM
Marco (nacioss) claimed this task.
Marco (nacioss) added a subscriber: Marco (nacioss).
It has been talked since ages, but since Cycles is an Unbiased render engine path tracing, then it won't have such a feature. Also this is not a bug so you shouldn't report it here feature requests, but here. And caustics in Cycles are calculated yes, but you need a lot of samples to get them to show. I would suggest you to use the Denoisier to remove the fireflies if you are using them.
Ok Thank You Marco ,
Can You advice me which render engine best for diamond Render if you please.
Thank You.
Because i want to use for my product designs for clients .
Thanks again .
LuxRender (also called LuxCore) is the best open source render engine for accurate caustics and dispersions, here, don't worry if it is still Beta for Blender 2.8, it's pretty stable.
V-Ray here and Corona here. Have fun.
Thanks a Lot !! Marco .
I gave a lot of time i didnt get results because, now will try in using other engines as you advised me .
Again Thanks a lot Marco .
