This issue is visible in the paint mode Tool Properties if you enable Gradient colors:
We could probably just add some slight padding in the color ramp template to fix this issue.
| rB Blender | |||
| D4831 | rB98b67d30ffdf Fix T64076: color ramp overlaps scrollbar | ||
| Status | Subtype | Assigned | Task | ||
| Confirmed | TO DO | None | T56950 UI Paper Cuts (Parent Task) | ||
| Resolved | TO DO | None | T64076 Gradient color stops overlap with scrollbars |
