Operating system: Windows 10
Graphics card: 1080
Broken: 2.8 ee0d8426ab6d
Joining two objects together with ctrl-j deletes the UV map of the joining object.
- Open the attached .blend file
- Select two objects
- Press ctrl-j
Result:
- The first selected objects UV map is deleted
Expected result:
- Both object's original UV maps should be retained even after they are joined
