Box select doesn't work for selecting handles in graph editor
Operating system: Windows-8.1-6.3.9600 64 Bits
Graphics card: GeForce GTX 970M/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 419.35
Broken: version: 2.80 (sub 60), branch: blender2.7, commit date: 2019-05-07 19:17, hash: rB3dc9da3a74ee
Box select doesn't select keyframe handles in graph editor. You can't select single handle of keyframe with box select. (Circle select works fine)
And if "show only selected keyframes handles" option is off you can't select handles of different keyframes with box select either.
  1. make a couple of keyframes for an object or bone
  2. try to select any single handle of keyframe with box select in graph editor
I should note that you have to untick the "Only selected keyframe handles" option to be able to reproduce this.
yes, when the option is OFF you can't select single handle (or more) and when option is ON you can't deselect handles and keyframes (to keep selected only single handle)
I cannot reproduce this. I can select handles when I set the keymap option to include handles.
The issue I have is different, but somehow related: When you select ONLY the parent Graph point, one of the handles is stuck if you try and move it.
Here is a GIF -
Workflow in the Gif: Right click select handles, then Circle select handles, then Box select (do nothing), then Box deselect handles on selected keyframe (do nothing also), and then again Box deselect with "Only selected keyframe handles" option on.
You need to alter the keymap. There is an option in the box select operator to detect handles or not. It’s off by default. So that part is not a bug.
But we can’t enable it currently because it exposes a different bug, as described above.
oh, didn't know that, with include handles it works fine for me. What is parent Graph point?
But if you enable that and only select the main point, not the handles, and try to move it, you get an issue where one handle is stuck.
Not critical at all. The goal is to select just two (or more) e.g. right side handles of two keyframes on different fcurves of specific bone on current frame and than e.g. scale them to zero so both handles had a same position. It allows you to get correct motion without any weird pops or something
To be honest, I'm not familiar with the transform operator code at all. Searching through it I found a comment mentioning a similar 'one handle stuck' problem (seemingly with curve objects), and some kind of hack to avoid that in that case.
I can't reproduce this. Box select works fine for me.
Sybren A. Stüvel (sybren) closed this task as Archived.Jan 6 2020, 2:42 PM
Sybren A. Stüvel (sybren) claimed this task.
Closing as 'Invalid' as two people haven't been able to repdouce this as currently described.
