Blender crashes
Windows 10
Operating system: windows 10
Graphics card:
Blender 2.8
Broken: (example: 2.80, edbf15d3c044, master, 2018-11-28, as found on the splash screen)
Blender crashes. The code works well, however after execution and the Ctrl Z is used to undo, Blender will crash and shut down. I am using the Bool Tool. Blender 2.79 also crashes. When you implement these functions without a script, it does not crash.
Demeter Dzadik (Mets) lowered the priority of this task from 90 to 30.May 13 2019, 3:08 PM
You can attach a .blend file by drag and dropping it into the text editor here. Surely you don't expect a developer to type out the script from the screenshot, and on top of that reconstruct your scene based on the script. :P
Brecht Van Lommel (brecht) changed the task status from Unknown Status to Unknown Status.May 21 2019, 11:42 AM
Closing due to lack of information to reproduce the issue, we can reopen the report if more information is provided.
