Outliner UI tooltips
Closed, ResolvedPublicDESIGN
In the outliner we don't have yet a clear distinction for the users of when to use each of the visibility settings. I plan to change that by properly naming the property and their tooltips.
Short version == what you see in the RNA API (likely never in the UI)
Long version == tooltip you see when mouse hover the property in outliner
Long version:
  • Exclude from view layer
  • Temporarily hide in viewport
  • Globally disable in viewports
  • Globally disable in renders
Short version:
  • Exclude from View Layer
  • Hide in Viewport
  • Disable in Viewports
  • Disable in Renders
The API itself does not need to change.
What I will change though is to remove any reference to instance we may still have lingering around.
Note: The order in the menus are different. So I'm also proposing to have the temporary hide before the global one.
Dalai Felinto (dfelinto) lowered the priority of this task from 90 to Normal.May 14 2019, 4:13 PM
Dalai Felinto (dfelinto) created this task.
Dalai Felinto (dfelinto) updated the task description. (Show Details)
Dalai Felinto (dfelinto) changed the task status from Unknown Status to Resolved.May 14 2019, 11:27 PM
Dalai Felinto (dfelinto) claimed this task.
