Viewport dead on Macpro
Operating system: high Sierra
Graphics card: AMD fire pro D700 6144 MB
Broken: f070bdd7c9c4
Viewport unresponsive for anything click and/or drag. I can click on menues, gizmos, tabs but anything related to the viewport itself doesn’t do anything with any mouse click LMB MMB RMB. . Default Blender installation.
William Reynish (billreynish) lowered the priority of this task from 90 to 30.May 15 2019, 3:27 PM
Try to use Load Factory Settings to make sure everything is default.
Can you record a screen recording that demos this exactly?
I tried to open the Pref Editor in the main window, no luck.
As for the video, I can't send anything out from the office, it's blocked for security reasons, but I found a clip that shows exactly what happens to me here: https://blenderartists.org/t/2-8-not-working-properly-on-my-macbook-pro-2018-not-able-to-orbit-or-select-with-the-trackpad/1159542
And I also get the invalid error when I go over the tools.
Oh sorry, this is a different problem than I wrote.
Could it be possible because I'm not running it as admin? I don't see why but just asking.
Philipp Oeser (lichtwerk) raised the priority of this task from 30 to 90.May 25 2019, 1:33 PM
Sebastian Parborg (zeddb) lowered the priority of this task from 90 to 30.Jun 11 2019, 5:25 PM
Is this with a track pad or an actual mouse?
Mouse. But in the video I posted above, the guy had the same problem with his trackpad.
Sebastian Parborg (zeddb) raised the priority of this task from 30 to 80.Jun 11 2019, 6:07 PM
Note that on the video, the status bar does not show assigned actions for mouse buttons.
And tool buttons tooltips - "Internal error!".
Maybe this will help.
Sebastian Parborg (zeddb) lowered the priority of this task from 80 to 30.Jun 12 2019, 10:25 AM
@Robert Rioux (riouxr) do you get any output if you start blender in the terminal with the -d flag?
This is what I get:
Switching to fully guarded memory allocator.
Blender 2.80 (sub 74)
Build: 2019-06-07 01:38:22 Darwin Release
argv[0] = ./blender
argv[1] = -d
Read prefs: /Users/rrioux/Library/Application Support/Blender/2.80/config/userpref.blend
read file
Version 280 sub 39 date unknown hash unknown
found bundled python: /Users/rrioux/Desktop/blender-2.80.0-git20190607.76634a23bbf7-x86_64/blender.app/Contents/Resources/2.80/python
Exception in module register(): /Users/rrioux/Desktop/blender-2.80.0-git20190607.76634a23bbf7-x86_64/blender.app/Contents/Resources/2.80/scripts/addons/cycles/__init__.py
File "/Users/rrioux/Desktop/blender-2.80.0-git20190607.76634a23bbf7-x86_64/blender.app/Contents/Resources/2.80/scripts/modules/addon_utils.py", line 384, in enable
  mod.register()
File "/Users/rrioux/Desktop/blender-2.80.0-git20190607.76634a23bbf7-x86_64/blender.app/Contents/Resources/2.80/scripts/addons/cycles/__init__.py", line 132, in register
  engine.init()
File "/Users/rrioux/Desktop/blender-2.80.0-git20190607.76634a23bbf7-x86_64/blender.app/Contents/Resources/2.80/scripts/addons/cycles/engine.py", line 122, in init
  _workaround_buggy_drivers()
File "/Users/rrioux/Desktop/blender-2.80.0-git20190607.76634a23bbf7-x86_64/blender.app/Contents/Resources/2.80/scripts/addons/cycles/engine.py", line 46, in _workaround_buggy_drivers
  if _is_using_buggy_driver():
File "/Users/rrioux/Desktop/blender-2.80.0-git20190607.76634a23bbf7-x86_64/blender.app/Contents/Resources/2.80/scripts/addons/cycles/engine.py", line 29, in _is_using_buggy_driver
  import re
File "/Users/rrioux/Desktop/blender-2.80.0-git20190607.76634a23bbf7-x86_64/blender.app/Contents/Resources/2.80/python/lib/python3.7/re.py", line 143, in <module>
  class RegexFlag(enum.IntFlag):
AttributeError: module 'enum' has no attribute 'IntFlag'
During handling of the above exception, another exception occurred:
File "/Users/rrioux/Desktop/blender-2.80.0-git20190607.76634a23bbf7-x86_64/blender.app/Contents/Resources/2.80/scripts/modules/bpy/__init__.py", line 81, in <module>
  main()
File "/Users/rrioux/Desktop/blender-2.80.0-git20190607.76634a23bbf7-x86_64/blender.app/Contents/Resources/2.80/scripts/modules/bpy/__init__.py", line 78, in main
  utils.load_scripts()
File "/Users/rrioux/Desktop/blender-2.80.0-git20190607.76634a23bbf7-x86_64/blender.app/Contents/Resources/2.80/scripts/modules/bpy/utils/__init__.py", line 274, in load_scripts
  _initialize()
File "/Users/rrioux/Desktop/blender-2.80.0-git20190607.76634a23bbf7-x86_64/blender.app/Contents/Resources/2.80/scripts/modules/addon_utils.py", line 47, in _initialize
  enable(addon.module)
File "/Users/rrioux/Desktop/blender-2.80.0-git20190607.76634a23bbf7-x86_64/blender.app/Contents/Resources/2.80/scripts/modules/addon_utils.py", line 390, in enable
  handle_error(ex)
File "/Users/rrioux/Desktop/blender-2.80.0-git20190607.76634a23bbf7-x86_64/blender.app/Contents/Resources/2.80/scripts/modules/addon_utils.py", line 299, in handle_error
  import traceback
File "/Users/rrioux/Desktop/blender-2.80.0-git20190607.76634a23bbf7-x86_64/blender.app/Contents/Resources/2.80/python/lib/python3.7/traceback.py", line 5, in <module>
  import linecache
File "/Users/rrioux/Desktop/blender-2.80.0-git20190607.76634a23bbf7-x86_64/blender.app/Contents/Resources/2.80/python/lib/python3.7/linecache.py", line 11, in <module>
  import tokenize
File "/Users/rrioux/Desktop/blender-2.80.0-git20190607.76634a23bbf7-x86_64/blender.app/Contents/Resources/2.80/python/lib/python3.7/tokenize.py", line 33, in <module>
  import re
File "/Users/rrioux/Desktop/blender-2.80.0-git20190607.76634a23bbf7-x86_64/blender.app/Contents/Resources/2.80/scripts/modules/bpy/utils/__init__.py", line 187, in register_module_call
  register()
File "/Users/rrioux/Desktop/blender-2.80.0-git20190607.76634a23bbf7-x86_64/blender.app/Contents/Resources/2.80/scripts/startup/bl_operators/__init__.py", line 70, in register
  register_class(cls)
ValueError: register_class(...): already registered as a subclass
  main()
File "/Users/rrioux/Desktop/blender-2.80.0-git20190607.76634a23bbf7-x86_64/blender.app/Contents/Resources/2.80/scripts/modules/bpy/utils/__init__.py", line 262, in load_scripts
  test_register(mod)
File "/Users/rrioux/Desktop/blender-2.80.0-git20190607.76634a23bbf7-x86_64/blender.app/Contents/Resources/2.80/scripts/modules/bpy/utils/__init__.py", line 229, in test_register
  register_module_call(mod)
File "/Users/rrioux/Desktop/blender-2.80.0-git20190607.76634a23bbf7-x86_64/blender.app/Contents/Resources/2.80/scripts/modules/bpy/utils/__init__.py", line 189, in register_module_call
  import traceback
  import linecache
  import tokenize
  import re
Keymap: '3D View Tool: Select Box' not found for tool 'builtin.select_box'
WARN (wm.keymap): /Users/gast/blender-buildbot/mac_x86_64_10_9_cmake/blender.git/source/blender/windowmanager/intern/wm_keymap.c:467 WM_keymap_poll: empty keymap 'Grease Pencil'
WARN (wm.keymap): /Users/gast/blender-buildbot/mac_x86_64_10_9_cmake/blender.git/source/blender/windowmanager/intern/wm_keymap.c:467 WM_keymap_poll: empty keymap 'Grease Pencil Stroke Edit Mode'
WARN (wm.keymap): /Users/gast/blender-buildbot/mac_x86_64_10_9_cmake/blender.git/source/blender/windowmanager/intern/wm_keymap.c:467 WM_keymap_poll: empty keymap 'Grease Pencil Stroke Paint Mode'
WARN (wm.keymap): /Users/gast/blender-buildbot/mac_x86_64_10_9_cmake/blender.git/source/blender/windowmanager/intern/wm_keymap.c:467 WM_keymap_poll: empty keymap 'Grease Pencil Stroke Paint (Draw brush)'
WARN (wm.keymap): /Users/gast/blender-buildbot/mac_x86_64_10_9_cmake/blender.git/source/blender/windowmanager/intern/wm_keymap.c:467 WM_keymap_poll: empty keymap 'Grease Pencil Stroke Paint (Erase)'
WARN (wm.keymap): /Users/gast/blender-buildbot/mac_x86_64_10_9_cmake/blender.git/source/blender/windowmanager/intern/wm_keymap.c:467 WM_keymap_poll: empty keymap 'Grease Pencil Stroke Paint (Fill)'
WARN (wm.keymap): /Users/gast/blender-buildbot/mac_x86_64_10_9_cmake/blender.git/source/blender/windowmanager/intern/wm_keymap.c:467 WM_keymap_poll: empty keymap 'Grease Pencil Stroke Sculpt Mode'
WARN (wm.keymap): /Users/gast/blender-buildbot/mac_x86_64_10_9_cmake/blender.git/source/blender/windowmanager/intern/wm_keymap.c:467 WM_keymap_poll: empty keymap 'Face Mask'
WARN (wm.keymap): /Users/gast/blender-buildbot/mac_x86_64_10_9_cmake/blender.git/source/blender/windowmanager/intern/wm_keymap.c:467 WM_keymap_poll: empty keymap 'Weight Paint Vertex Selection'
WARN (wm.keymap): /Users/gast/blender-buildbot/mac_x86_64_10_9_cmake/blender.git/source/blender/windowmanager/intern/wm_keymap.c:467 WM_keymap_poll: empty keymap 'Pose'
WARN (wm.keymap): /Users/gast/blender-buildbot/mac_x86_64_10_9_cmake/blender.git/source/blender/windowmanager/intern/wm_keymap.c:467 WM_keymap_poll: empty keymap 'Object Mode'
WARN (wm.keymap): /Users/gast/blender-buildbot/mac_x86_64_10_9_cmake/blender.git/source/blender/windowmanager/intern/wm_keymap.c:467 WM_keymap_poll: empty keymap 'Paint Curve'
WARN (wm.keymap): /Users/gast/blender-buildbot/mac_x86_64_10_9_cmake/blender.git/source/blender/windowmanager/intern/wm_keymap.c:467 WM_keymap_poll: empty keymap 'Curve'
WARN (wm.keymap): /Users/gast/blender-buildbot/mac_x86_64_10_9_cmake/blender.git/source/blender/windowmanager/intern/wm_keymap.c:467 WM_keymap_poll: empty keymap 'Image Paint'
WARN (wm.keymap): /Users/gast/blender-buildbot/mac_x86_64_10_9_cmake/blender.git/source/blender/windowmanager/intern/wm_keymap.c:467 WM_keymap_poll: empty keymap 'Vertex Paint'
WARN (wm.keymap): /Users/gast/blender-buildbot/mac_x86_64_10_9_cmake/blender.git/source/blender/windowmanager/intern/wm_keymap.c:467 WM_keymap_poll: empty keymap 'Weight Paint'
WARN (wm.keymap): /Users/gast/blender-buildbot/mac_x86_64_10_9_cmake/blender.git/source/blender/windowmanager/intern/wm_keymap.c:467 WM_keymap_poll: empty keymap 'Sculpt'
WARN (wm.keymap): /Users/gast/blender-buildbot/mac_x86_64_10_9_cmake/blender.git/source/blender/windowmanager/intern/wm_keymap.c:467 WM_keymap_poll: empty keymap 'Mesh'
WARN (wm.keymap): /Users/gast/blender-buildbot/mac_x86_64_10_9_cmake/blender.git/source/blender/windowmanager/intern/wm_keymap.c:467 WM_keymap_poll: empty keymap 'Armature'
WARN (wm.keymap): /Users/gast/blender-buildbot/mac_x86_64_10_9_cmake/blender.git/source/blender/windowmanager/intern/wm_keymap.c:467 WM_keymap_poll: empty keymap 'Metaball'
WARN (wm.keymap): /Users/gast/blender-buildbot/mac_x86_64_10_9_cmake/blender.git/source/blender/windowmanager/intern/wm_keymap.c:467 WM_keymap_poll: empty keymap 'Lattice'
WARN (wm.keymap): /Users/gast/blender-buildbot/mac_x86_64_10_9_cmake/blender.git/source/blender/windowmanager/intern/wm_keymap.c:467 WM_keymap_poll: empty keymap 'Particle'
WARN (wm.keymap): /Users/gast/blender-buildbot/mac_x86_64_10_9_cmake/blender.git/source/blender/windowmanager/intern/wm_keymap.c:467 WM_keymap_poll: empty keymap 'Font'
WARN (wm.keymap): /Users/gast/blender-buildbot/mac_x86_64_10_9_cmake/blender.git/source/blender/windowmanager/intern/wm_keymap.c:467 WM_keymap_poll: empty keymap 'Object Non-modal'
WARN (wm.keymap): /Users/gast/blender-buildbot/mac_x86_64_10_9_cmake/blender.git/source/blender/windowmanager/intern/wm_keymap.c:467 WM_keymap_poll: empty keymap 'Frames'
WARN (wm.keymap): /Users/gast/blender-buildbot/mac_x86_64_10_9_cmake/blender.git/source/blender/windowmanager/intern/wm_keymap.c:467 WM_keymap_poll: empty keymap '3D View Generic'
WARN (wm.keymap): /Users/gast/blender-buildbot/mac_x86_64_10_9_cmake/blender.git/source/blender/windowmanager/intern/wm_keymap.c:467 WM_keymap_poll: empty keymap '3D View'
WARN (wm.keymap): /Users/gast/blender-buildbot/mac_x86_64_10_9_cmake/blender.git/source/blender/windowmanager/intern/wm_keymap.c:467 WM_keymap_poll: empty keymap 'Window'
WARN (wm.keymap): /Users/gast/blender-buildbot/mac_x86_64_10_9_cmake/blender.git/source/blender/windowmanager/intern/wm_keymap.c:467 WM_keymap_poll: empty keymap 'Screen'
WARN (wm.keymap): /Users/gast/blender-buildbot/mac_x86_64_10_9_cmake/blender.git/source/blender/windowmanager/intern/wm_keymap.c:467 WM_keymap_poll: empty keymap 'Screen Editing'
WARN (wm.keymap): /Users/gast/blender-buildbot/mac_x86_64_10_9_cmake/blender.git/source/blender/windowmanager/intern/wm_keymap.c:467 WM_keymap_poll: empty keymap 'User Interface'
WARN (wm.keymap): /Users/gast/blender-buildbot/mac_x86_64_10_9_cmake/blender.git/source/blender/windowmanager/intern/wm_keymap.c:467 WM_keymap_poll: empty keymap 'View2D'
WARN (wm.keymap): /Users/gast/blender-buildbot/mac_x86_64_10_9_cmake/blender.git/source/blender/windowmanager/intern/wm_keymap.c:467 WM_keymap_poll: empty keymap 'Region Context Menu'
WARN (wm.keymap): /Users/gast/blender-buildbot/mac_x86_64_10_9_cmake/blender.git/source/blender/windowmanager/intern/wm_keymap.c:467 WM_keymap_poll: empty keymap 'View2D Buttons List'
WARN (wm.keymap): /Users/gast/blender-buildbot/mac_x86_64_10_9_cmake/blender.git/source/blender/windowmanager/intern/wm_keymap.c:467 WM_keymap_poll: empty keymap 'Property Editor'
WARN (wm.keymap): /Users/gast/blender-buildbot/mac_x86_64_10_9_cmake/blender.git/source/blender/windowmanager/intern/wm_keymap.c:467 WM_keymap_poll: empty keymap 'Animation'
WARN (wm.keymap): /Users/gast/blender-buildbot/mac_x86_64_10_9_cmake/blender.git/source/blender/windowmanager/intern/wm_keymap.c:467 WM_keymap_poll: empty keymap 'Dopesheet Generic'
Have you installed any python modules?
According to this is seems like you might have some conflicting libraries installed:
https://stackoverflow.com/questions/43124775/why-python-3-6-1-throws-attributeerror-module-enum-has-no-attribute-intflag
I had these empty keymap errors (no intflag error though), and fixed it.
In a fresh git build, I forgot to run 'make install' after 'make' in my build dir.
(What gave the clue was some .py errors in terminal when quitting, making me realize I might have mismatched file versions.)
Brecht Van Lommel (brecht) changed the task status from Unknown Status to Unknown Status.Jun 29 2019, 3:43 PM
There are two possible causes for this. Either you have a conflicting Python installation, see here:
https://docs.blender.org/manual/en/dev/troubleshooting/python.html#pythonpath
Or there is an add-on installed incorrectly which includes an enum.py file. For that you can move all files out of this folder and only move back valid working add-ons.
Library/Application Support/Blender/2.80/scripts/addons
