Blender 2.80 Eevee and Cycle fails in Intel integrated graphic UHD cards
Closed, DuplicatePublic
Operating system: Windows 10 Home v. 1809 lenovo yoga 520 16Gb Ram i5
Graphics card: Intel UHD Graphics 620
Broken: blender-2.80.0-git.27d097e92d54-windows64 Date: 2019-05-13 and later
When you open a new or older archive and selecte Eevee or Cycles and enter in lookdev or rendered mode in Eevee or in Cycles engine. Then Objects not selected are hided, and you can only see the silhouette from selected object you can't view the faces or solid materials.
I add two screenshots so you can see what happens.
this is in Lookdev mode in Eevee same occurs for Cycles. In workbench mode works fine.
And this is in solid mode. Solid and wireframe works fine. but lookdev and rendered fails.
Simply open Blender and in new general file with cube in the center (File/New/General) select Eevee or Cycles as a render engine and change display mode to lookdev or rendered.
