App Crash when adjusting RGB Curves Node
Graphics card: GeForce GTX 745/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 417.35
Broken: version: 2.80 (sub 64), branch: master, commit date: 2019-05-15 23:47, hash: rB02a7e57d9c07
Application consistently crashes when using the RGB Curve node
  1. Add RGB Curve node to Shader Nodes (you can attach it to something or not)
  2. Adjust the Curve in any direction
  3. Application crashes when you release the mouse button
Brecht Van Lommel (brecht) lowered the priority of this task from 90 to 30.May 21 2019, 4:02 PM
Please attach a .blend file to reproduce the issue, I couldn't redo it. This is likely affected by the render engine, which editors you have open, etc.
Demeter Dzadik (Mets) changed the task status from Unknown Status to Unknown Status.May 30 2019, 5:50 PM
Demeter Dzadik (Mets) claimed this task.
I'm assuming it crashed during Eevee shader compilation(but then again, you didn't even specify what render engine you were using), and I think a lot of those crashes were fixed somewhat recently. I'm closing this for now, please try on the latest 2.80 and if it still happens you can feel free to re-open this. And if you do, you should also attach a blend file to help reproduce it and/or make a video of the crash.
