Glass and Gloss BDSF Shaders don't work in cycles
Operating system: Windows 10
Graphics card: GTX 1080
Broken: (example: 2.80, edbf15d3c044, master, 2018-11-28, as found on the splash screen)
I think that this has been a problem since I started using blender 2.8 but I use cycles and the glass and gloss shaders don't seem to work for me. When I render the shaders out I just end up with a chunk of black that is not clear nor reflective{F7044609}
There are several issues with this blend file.
  1. You have no lights in your scene. Either add a light source, or enable all the World Settings -> Ray Visibility check boxes in the Properties editor.
  2. Render Settings -> Light Paths -> Max Bounces: All of these settings should probably be greater than 0 to get a non-black image.
After making these changes, the scene renders just fine.
Brecht Van Lommel (brecht) changed the task status from Unknown Status to Unknown Status.May 18 2019, 1:09 PM
That's correct, this is not a bug.
