Alpha Blend behavior changed
Operating system: Windows-10 17763 x64
Graphics card: Radeon RX Vega 64
Broken: version: 2.80 (sub 71), branch: master, commit date: 2019-05-21 16:07, hash: rB522320dadf5a
Worked: early May and earlier builds
I have several projects that make extensive use of Images using 'Alpha Blend' in the material settings for transparancy around hand drawn characters, In the new builds 'Alpha Blend' makes the whole image plane invisible. If I change 'Alpha Blend' to 'Alpha Clip' the images work again
Is this a change to how 'Alpha Blend' works, or a bug?
using an image with alpha channel (PNG) import to Blender "Images as Planes" and in material settings set 'Blend Mode to 'Alpha Blend' the alpha channel should dissapear leaving the drawing. Right now the whole image is invisible.
Opaque
Alpha Clip
Alpha Blend
Brecht Van Lommel (brecht) lowered the priority of this task from 90 to 30.EditedMay 21 2019, 7:05 PM
There were indeed changes.
https://devtalk.blender.org/t/13-may-2019/7076
We require an example .blend file and image to investigate bugs.
Tom Nelson (tomnel) added a comment.EditedMay 21 2019, 7:25 PM
It works using the new Principled BSDF shader method, looks like I have a lot of project files to change!
The price of progress...
Thanks!
Tom Nelson (tomnel) changed the task status from Unknown Status to Resolved.May 21 2019, 7:26 PM
Tom Nelson (tomnel) claimed this task.
