Operating system: Windows 10 x64
Graphics card: Nvidia GTX 1080 (SLI)
Broken: May 26, 00:26:30 - f18373a9ab1a
When using any Particle Simulation, even the simplest, adding a reflection plane to the scene and try to render in viewport, or F12, blender crash.
Based on the default startup .blend file.
Add particle system to default cube
Add another smaller cube to use as particle object.
Go into default cube > particle system > render > object > """add the previous small cube as object""" (set scale like to 0.1 or 1)
Switch to render viewport mode
Play the simulation (all is going as expected)
Stop the simulation, go to frame 1
Turn back to shaded viewport mode
Add reflection plane
Play the simulation
Blender Crash.
