error in mesh view in sculpt mode
Operating system: Ubuntu 18.04.2 LTS
Graphics card: NV96/GeForce 9500 GT
Broken: 2.80 Beta Linux 32 bit May 27, 00:30:16 - d525c76003b3 Beta 117.15MB (example: 2.80, edbf15d3c044, master, 2018-11-28, as found on the splash screen)
Worked: 2.79.b+dfsg0-1ubuntu1.18.04.1(optional)
esculpt mode does not show the mesh correctly, although it modificala correctly
any change in the mesh is not correctly represented in esculpt mode
1- Create a plan
2- add multiresolution
3- subdivide 3x and apply
4- go to sculpt mode
obs .: with 2 or 1 subdivide there are no errors/ the error occurs when the mesh complexity increases
after using sculpting with dyntopo ->
Brecht Van Lommel (brecht) changed the task status from Unknown Status to Unknown Status.May 29 2019, 1:37 AM
This graphics card is outside the range of cards that we support, so if this a graphics issue we would not spend time fixing it:
https://code.blender.org/2019/04/supported-gpus-in-blender-2-80/
If it's an issue with the sculpt tools causing problems, we have similar bug reports about this open, for example T58920: Dyntopo sculpt and snake hook brush artifacts.
this board has opengl 3.3 support. It is very sad to know that the blender will not handle the message. I use it with blender and 3d unity to create games. the way is to embrace blender 2.79 xD
Funny that in Dyntopo, activating and deactivating smooth shading causes the mesh to be correct again
but if you keep doing it many times the program closes alone
