Keyframes that won't deselect or delete.
Operating system: Windows 10
Graphics card: NVIDIA GTX 1050Ti
Broken: 2.80, d525c76003b3, 2019-05-26 22:34
In the Dope Sheet's Action Editor I have some keyframes which are yellow even when they are not selected - even deleting them does not make them go away. The keyframe that shows on the Summary line does go away, but not in the bone channel.
I linked a character rig, made it into a proxy, created an action and started animating. I am not sure what exactly caused it - though I suspect maybe it has something to do with copy and pasting keyframes, including using "paste flipped". For example, I first started noticing something was wrong after rotating 1 arm bone (auto key on), moving ahead and then pressing Ctrl-Shift-V to paste flipped and rather than pasting onto the opposite arm it messed up the currently select arm. Yet if I deselect all bones (Alt-A) then Paste Flipped, it works correctly. I'm not sure if that is expected behavior (I hope not), but shortly after that I noticed the glitched keyframes that wouldn't deselect or be deleted.
Also, if I select some keyframes, I can't deselect them by just click in empty space. I opened up a new file and this is working there - just not in the previously described corrupted file.
Brecht Van Lommel (brecht) lowered the priority of this task from 90 to 30.May 28 2019, 3:05 AM
We require an example .blend file to reproduce the problem.
Hi. I will attach a zip. Inside you will find the original mesh at "/Mesh/BlockGuy.blend", the rig (which proxies the mesh) at "/Mesh/BlockGuy_RIG.blend" and then the corrupted file is at "/Anim/BlockGuy_Anim_Walk.blend" (which proxies the rig).
Brecht Van Lommel (brecht) raised the priority of this task from 30 to 90.Jun 7 2019, 11:20 AM
Sebastian Parborg (zeddb) changed the task status from Unknown Status to Unknown Status.Jun 13 2019, 2:25 PM
Sebastian Parborg (zeddb) claimed this task.
They appear selected because you are using a filter rot (top left). If you remove the filter you can see (and deselect all keyframes).
