Graphics card: GeForce GTX 960M/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 430.86
Broken: version: 2.80 (sub 72), branch: blender2.7, commit date: 2019-05-29 18:17, hash: rBfee600f47980
Worked: version 2.79
EDIT: Converting a curve to mesh does not take the use of a bevel object into account, when you have Keep Original checked in the Redo Panel.
- Create two curves
- Use one as the "path" curve and the other as the "bevel object" in Properties editor -> Object Data tab -> Geometry -> Bevel -> Object field
- EDIT: Select the "path" curve and convert it to mesh via Object -> Convert to -> Mesh from Curve/Meta/Surf/Text and check Keep Original.
Results in the "path" curve being converted to mesh, not the generated mesh from using the "bevel object" as it happens in version 2.79.bold text
