I cannot select or move anything in the viewport and tool tip = internal error
Operating system: Win 10 home - 17763.529
Graphics card: Nvidia 1060 with max q - 430.86
Broken: (V2.80.73 and V2.80.71)
Worked: (2.80.47)
I have a older bild (2.80.47) where everything works just fine...
I'm not sure if it is a bug
This comment was removed by Isak Thjellesen (Harvid).
William Reynish (billreynish) lowered the priority of this task from 90 to 30.Jun 4 2019, 7:54 PM
Try doing File>Defaults>Load Factory Settings and re-test.
I did try to reload Factory Settings but it did not work.
But problems disappeared when i deleted the Blender folder in \AppData\Roaming\Blender Foundation\..
So that's probably not a problem in final 2.80 with a real installer.
Sorry for the Trouble and Thank you for the help
William Reynish (billreynish) changed the task status from Unknown Status to Archived.Jun 4 2019, 8:30 PM
ok - it's possible that some old beta install caused this issue. Marking as invalid.
I would like to re open this ticket please. (Windows 10, nVidia 1080)
For quite some time I'd been checking out Blender 2.8. However stayed at 2.79 as to not loose any work being beta.
The past several months however, this exact issue had appeared.
Download 2.8, run it. It opens fine. However the most that can be done is changing layout tabs. When doing so, Blender 2.8 screams errors.
I was excited to see the above and tried out the actions described. However no effect.
Here is a link to errors that I could show. However the UI is still locked to where I cannot open the windows to display more than this. Tabs still work.
ERROR IMAGE
Can only claim this showed up several months ago. I remember at least at the turn of the year, I was able to down the the beta, and it operated with no problem. When it first started happening, figured it was work in progress. Next couple of times I checked, same issue.
However this is now RC1.
As above, hovering the mouse over any buttons gives a red "internal error" tool tip.
Cannot click or select anything. Cannot grab and adjust window sizes (except for the over all application window).
Tried loading factor defaults.
Tried deleting the Blender user profiles, which resets it. Still same non-response.
Hunting for an answer, it does feel like this may not be common.
Will try it on other machines to see if the same problem occurs.
If this is something common, any tips to or actions suggested?
