rendering 100% hdtv resolution crashes
Hi!
Open Blender and choose HD resolution in the render settings. Rendering at 100% crashes Blender. Other percentages work fine.
I use:
Blender 2.43 official
Windows XP Home 32bit
Ati X800XL
Regards,
Sladi
Logged In: YES
user_id=103
Hi,
This is not a good bugreport. We need something to redo you know, and you could have tested yourself that this is not a general bug in Blender.
Probably it is because of your graphics card...
Try to render any size larger than the screen you have?
Also, to bypass the error you can use "render to image window" instead, an option you can find in the "Render Output" panel.
Matt Ebb (broken) changed the task status from Unknown Status to Unknown Status.Mar 26 2010, 6:37 AM
