To activating "Emulate numeric keypad" It does not work for me the shortcut of "Object Edit Mode", to select: Edge, point and face of objects.
Graphics card: TITAN Xp/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 430.86
Broken: version: 2.80 (sub 74), branch: blender2.7, commit date: 2019-06-16 23:08, hash: rB12da679fa094
When activating "Emulate numeric keypad", the shortcut of Object Edit Mode, to select edge, point, face, does not work. What solution is there? Thanks in advance
Activate in preferences, mode: Emulate numeric keypad.
Choose any object in the camera view, for example the cube.
Activate the Object Edit mode by pressing the TAB key.
Now try to select the edges, points or faces of the object; using only the keyboard shortcut: 1, 2, or 3, ...
Now they do not work ...
Thanks in advance?
On solution would be to leave emulate numeric keypad off and use the ~ pie menu to switch views. Alternatively you could assign new shortcuts to the different selection modes in your keymap or use the onscreen buttons to change selection modes.
Sebastian Parborg (zeddb) changed the task status from Unknown Status to Archived.Jun 21 2019, 11:09 AM
Sebastian Parborg (zeddb) claimed this task.
Not a bug. It does exactly what it is meant to do, map the 1 to 0 key row to the numpad keys.
