Crash when switching SR windows
This only happens with one particular file using both 2.43 and Publisher 2.25. It happened after I moved a GIF file that was referenced in the sequencer.
Date/Time: 2007-04-19 11:31:49.391 -0700
OS Version: 10.4.9 (Build 8P135)
Report Version: 4
Command: blender
Path: /Users/phampton/Documents/blender-2.43-OSX-10.3-py2.3-powerpc/blender.app/Contents/MacOS/blender
Parent: WindowServer [61]
Version: 2.43 (2.43, 2007-Feb-17, Blender Foundation)
PID: 420
Thread: Unknown
Link (dyld) error:
image not found
Model: PowerMac4,2, BootROM 4.4.0f1, 1 processors, PowerPC G4 (2.1), 800 MHz, 1 GB
Graphics: NVIDIA GeForce2 MX, GeForce2 MX, AGP, 32 MB
Memory Module: DIMM0/J12, 512 MB, SDRAM, PC100-322S
Memory Module: DIMM1/J13, 512 MB, SDRAM, PC133-333
AirPort: AirPort, 9.52
Modem: Dash2, UCJ, V.92, 1.0F, APPLE VERSION 2.6.6
Network Service: Built-in Ethernet, Ethernet, en0
Parallel ATA Device: ST380021A, 74.53 GB
Parallel ATA Device: PIONEER DVD-RW DVR-104
USB Device: USB Printer, EPSON, Up to 12 Mb/sec, 500 mA
USB Device: ORTEK KH12 USB Hub, ORTEK, Up to 12 Mb/sec, 500 mA
USB Device: USB-PS/2 Optical Mouse, Logitech, Up to 1.5 Mb/sec, 100 mA
USB Device: USB Hub/Keyboard, ORTEK, Up to 12 Mb/sec, 250 mA
Logged In: YES
user_id=103
- What is an "SR Window"?
- How do you "use both 2.43 and Publisher 2.25"?
Did you read the "OSX hints" notes in the distro? It gives clues for people using graphics cards with only little memory (this PPC system is quite old).
Most important, set your graphics to "thousands of colors"
Logged In: YES
user_id=3216
If I deselect 'Load UI' before saving that seems to solve the problems between the various Macs I use on campus.
Thanks for your reply. I read the docs you suggested.
Pam
Matt Ebb (broken) changed the task status from Unknown Status to Unknown Status.Mar 26 2010, 6:37 AM
