unlink error
Operating system: Kubuntu 16.04
Graphics card: nvidia geforce 1070
Broken: c0c1b4542f39
Worked: 2.79
unlink_objects seems to be broken
create cube
make an instance with alt-d
select duplicate, run Unlink_Objects
I can make the object/data single user from the object menu just fine, not sure if there's a difference, just figured I'd point it out.
Philipp Oeser (lichtwerk) lowered the priority of this task from 90 to 30.Jun 26 2019, 11:41 AM
Not sure I understand correctly:
  • how exactly are you running "unlink_objects"
  • (not even sure this is a builtin operator?)
I set the search function to the space bar, typed in unlink just like in 2.79 (worked with the U hotkey in 2.79,I'm guessing that stood for unlink).
in 2.8, if you type "unlink" [mesh object in objectmode], I am getting:
  • "Unlink Collection"
  • "Remove From All Unlinked Collections"
in 2.79 I am getting:
  • "Unlink Group"
Make Single User has:
  • Object
  • Object & Data
If I run make single user from the search, this seems to work...
is this an addon (are you getting this with)? [or am I still misunderstanding?]
You're right, after checking the error message more carefully it seems it was an issue with the hardops add-on - sorry about that. It got me confused because I used it often in 2.79 and I wasn't realizing it's not the built in way of doing this.
Philipp Oeser (lichtwerk) changed the task status from Unknown Status to Archived.Jun 27 2019, 9:17 AM
Ok, thx for getting back, in the case of hardops, this is not maintained by blender, please report the issue to the original author instead
