same material on two face, but display different result
Operating system: Windows 10
Graphics card: Nvidia 1070
version: 2.80 (sub 74), branch: master, commit date: 2019-06-28 22:08, hash: 648e8a1f1d4a, type: Release
build date: 28/06/2019, 17:58
Please see attached blender file{F7555453}, I set the same material in two surface, but the display is different.
Brecht Van Lommel (brecht) changed the task status from Unknown Status to Unknown Status.Jun 29 2019, 11:02 AM
The displacement setup for this material makes no sense.
czf (czf) changed the task status from Unknown Status to Unknown Status.Jul 1 2019, 3:55 AM
"Mix Shader and Shader to RGB should not be part of displacement nodes: "
I can remove mix shader and shader to RGB. and the result is no change. attached screenshots shows the this{F7557884}
"There is no Displacement node used."
displacement nod can't be use in eevee ?  But why it takes  effect when I use it?
The same material is inconsistent on both surfaces is the problem
czf (czf) changed the task status from Unknown Status to Resolved.Jul 1 2019, 9:33 AM
I add displacement node and solved this problem. thanks!
