Blender 2.81, 2.82, ...
Worked: ?
Unable to rename grease pencil layer when tooltip says: 'Active layer index, Double click to rename.'
- Go to either '2D Full Canvas' or ' 2D Animation',
- Add a blank Grease Pencil,
- Change mode to Draw
- Drag the header bar to left to review 'Layer:'
- Click the down arrow to show the layer's panel
- Press + there to add a new layer
- Select either old or new layer and while leaving mouse pointer hover over it, you should see a tooltip 'Active layer index, Double click to rename.' Try to double click on it and 'NOTHING HAPPENS'.
- In 2D Animation layout you can access the 'Properties' panel on the left and rename there, in 2D Full canvas, you'll have to split window, creating a new one, change it to Properties before you can do the 'RENAME'.
Screenshot for ' 2D Full canvas' layout, rename is IMPOSSIBLE:
Screenshot for '2D Animation' layout, rename is IMPOSSIBLE:
Screenshot for the same control in Properties panel, where RENAME is possible:
