select another UV set in UV editor works only on highlited object, when you multi edit different objects with same uv sets
Operating system: Windows-10-10.0.14393 64 Bits
Graphics card: Radeon (TM) RX 480 Graphics ATI Technologies Inc. 4.5.13558 Core Profile Context 26.20.11015.5009
Broken: version: 2.80 (sub 74), branch: master, commit date: 2019-07-02 13:31, hash: rBe7356bb01198
make cube, add second uv set for it. Copy cube several times. Select all objects and go to multi edit mode. go to UV editor and try to switch uv set in right down corner.
Philipp Oeser (lichtwerk) changed the task status from Unknown Status to Unknown Status.Jul 3 2019, 11:19 AM
Yes, this is doing it for the (single) edit_object
mesh = context.edit_object.data
layout.prop_search(mesh.uv_layers, "active", mesh, "uv_layers", text="")
There are multiple places like these in blender [where - even in multi-edit-mode - settings are displayed for the active object/mesh only...]
This is planned to be improved (@William Reynish (billreynish) : I think there was a task for it? cant find it atm...), but I think this is not considered a bug at this point...
Will close [unless @William Reynish (billreynish) has objections?]
