The sub-menus are not visible until you hover over them or until you click on their menu parent. The correct behavior is - that they are visible from the moment you hover over their parent. This is especially annoying when selecting modifiers, because you have to anticipate the sub-menu position and go there with your mouse for the menu to show.
This is only related to the desktop-rotated mode (tested with Nvidia 90° rotation)
Comment Actions
Logged In: YES
user_id=103
Interesting, what is this new mode?
Do note that Blender does nothing but use opengl for the UI. When things don't draw well, it means opengl is messed up. Nothing we can fix really, apart from adding another bypass/hack in our code...
Comment Actions
Logged In: YES
user_id=6116
It is a simple rotation of the desktop - when you rotate your LCD 90 degrees, you can work in "Portrait"
Comment Actions
