Linking an unused Light datablock to an existing light object crashes Blender.
Closed, ResolvedPublicBUG
Graphics card: GeForce GTX 1080/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 430.86
Broken: version: 2.80 (sub 74), branch: master, commit date: 2019-05-31 22:45, hash: rBcc600de6695a
If you create multiple lights, you can make them all linked so that changing properties of one of the instances will change all of the lights.
But if a light datablock is unlinked or deleted and then selected as the linked object, Blender will crash.
First I startup Blender file and create a plane and adjust the object locations to see stuff better. Then I go to Rendered shading mode (I'm using Cycles).
Then I create 2 more lights by duplicating with Ctrl+D. I change the colours of the new lamps.
Now, just to show how things should (probably) work, I select the original lamp and in the object data properties menu, I select it to be linked to the blue lamp.
Lighting of the scene will not update until I move the changed lamp in the viewport or go to eg. solid shading mode and return to Cycles rendered shading mode.
If I now delete the lamp.002 and create a new lamp and try to link the newly created lamp with lamp.002 datablock, I've broken Blender. If I now move the brokenly linked lamp, Blender will crash.
In this last picture, we can observe that even though I deleted lamp.002, I can set the NEWLAMP object to be lamp.002. But as we can see, the light didn't change red as it should have. I then changed the shading mode to solid and returned back to Rendered shading mode and Blender crashed - but Blender will also crash if the lamp is moved.
I can reproduce the crash! (Ubuntu 18.04.2, hwe kernel 4.18.0-25-generic, CPU i7-4800MQ, running on iGPU).
Here is /tmp/blender-crash.txt:
Blender 2.80 (sub 74), Commit date: 2019-07-04 12:18, Hash 2ee257e2c34f
bpy.context.space_data.context = 'RENDER' # Property
bpy.context.scene.render.engine = 'CYCLES' # Property
bpy.ops.object.duplicate_move(OBJECT_OT_duplicate={"linked":False, "mode":'TRANSLATION'}, TRANSFORM_OT_translate={"value":(-0.900137, -2.78419, -0.605438), "orient_type":'GLOBAL', "orient_matrix":((1, 0, 0), (0, 1, 0), (0, 0, 1)), >"orient_matrix_type":'GLOBAL', "constraint_axis":(False, False, False), "mirror":True, "use_proportional_edit":False, "proportional_edit_falloff":'SMOOTH', "proportional_size":1, "use_proportional_connected":False, >"use_proportional_projected":False, "snap":False, "snap_target":'CLOSEST', "snap_point":(0, 0, 0), "snap_align":False, "snap_normal":(0, 0, 0), "gpencil_strokes":False, "cursor_transform":False, "texture_space":False, "remove_on_cancel":False, >"release_confirm":False, "use_accurate":False}) # Operator
bpy.ops.object.duplicate_move(OBJECT_OT_duplicate={"linked":False, "mode":'TRANSLATION'}, TRANSFORM_OT_translate={"value":(-2.48568, -5.10081, 0.427437), "orient_type":'GLOBAL', "orient_matrix":((1, 0, 0), (0, 1, 0), (0, 0, 1)), >"orient_matrix_type":'GLOBAL', "constraint_axis":(False, False, False), "mirror":True, "use_proportional_edit":False, "proportional_edit_falloff":'SMOOTH', "proportional_size":1, "use_proportional_connected":False, >"use_proportional_projected":False, "snap":False, "snap_target":'CLOSEST', "snap_point":(0, 0, 0), "snap_align":False, "snap_normal":(0, 0, 0), "gpencil_strokes":False, "cursor_transform":False, "texture_space":False, "remove_on_cancel":False, >"release_confirm":False, "use_accurate":False}) # Operator
bpy.data.screens["Layout"].shading.type = 'RENDERED' # Property
bpy.context.space_data.context = 'DATA' # Property
bpy.ops.object.delete(use_global=False) # Operator
Deleted 1 object(s) # Info
bpy.ops.object.light_add(type='POINT', radius=1, location=(0, 0, 0)) # Operator
bpy.ops.transform.translate(value=(-4.21024, -3.87805, 4.58718), orient_type='GLOBAL', orient_matrix=((1, 0, 0), (0, 1, 0), (0, 0, 1)), orient_matrix_type='GLOBAL', mirror=True, use_proportional_edit=False, proportional_edit_falloff='SMOOTH', >proportional_size=1, use_proportional_connected=False, use_proportional_projected=False) # Operator
__
backtrace
./blender(BLI_system_backtrace+0x1d) [0x135f82d]
./blender() [0x1148199]
/lib/x86_64-linux-gnu/libc.so.6(+0x3ef20) [0x7f6403db8f20]
./blender(_ZN3ccl6Shader8tag_usedEPNS_5SceneE+0) [0x3d9fa40]
./blender(_ZN3ccl11BlenderSync11find_shaderERN2BL2IDERNS_6vectorIPNS_6ShaderENS_16GuardedAllocatorIS6_EEEES6_+0xed) [0x157de1d]
./blender(_ZN3ccl11BlenderSync10sync_lightERN2BL6ObjectEPiS3_S3_iRNS_9TransformEPb+0x77c) [0x155ee5c]
./blender(_ZN3ccl11BlenderSync11sync_objectERN2BL9DepsgraphERNS1_9ViewLayerERNS1_23DepsgraphObjectInstanceEfbbRNS_20BlenderObjectCullingEPb+0xc2a) [0x156025a]
./blender(_ZN3ccl11BlenderSync12sync_objectsERN2BL9DepsgraphEf+0x771) [0x1561ce1]
./blender(_ZN3ccl11BlenderSync9sync_dataERN2BL14RenderSettingsERNS1_9DepsgraphERNS1_11SpaceView3DERNS1_6ObjectEiiPPv+0x16a) [0x1552baa]
./blender(_ZN3ccl14BlenderSession11synchronizeERN2BL9DepsgraphE+0x648) [0x15472f8]
./blender() [0x153dc5d]
./blender(_PyMethodDef_RawFastCallKeywords+0x2b9) [0x17455a9]
./blender(_PyCFunction_FastCallKeywords+0x25) [0x1745665]
./blender(_PyEval_EvalFrameDefault+0x8d5f) [0x114425f]
./blender() [0x113a450]
./blender(_PyEval_EvalFrameDefault+0x79c3) [0x1142ec3]
./blender(_PyFunction_FastCallDict+0x2a6) [0x1745026]
./blender() [0x13dc2ee]
./blender() [0x14b0fe7]
./blender(ED_render_scene_update+0x1bb) [0x3e7e1fb]
./blender(DEG_ids_check_recalc+0x46) [0x1369206]
./blender() [0x126cccd]
./blender(wm_event_do_depsgraph+0xc3) [0x150e5b3]
./blender(wm_event_do_refresh_wm_and_depsgraph+0x87) [0x150e717]
./blender(wm_event_do_notifiers+0x472) [0x1513fe2]
./blender(WM_main+0x28) [0x150a658]
./blender(main+0x2fe) [0x10b59de]
/lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xe7) [0x7f6403d9bb97]
./blender() [0x1144abc]
Sybren A. Stüvel (sybren) lowered the priority of this task from 90 to High.
I can confirm this. Here is a stack trace from a debug build:
==8229==ERROR: AddressSanitizer: SEGV on unknown address 0x00000000006c (pc 0x55febb7aa292 bp 0x7ffea81a5080 sp 0x7ffea81a5070 T0)
==8229==The signal is caused by a READ memory access.
==8229==Hint: address points to the zero page.
    #0 0x55febb7aa291 in ccl::Shader::tag_used(ccl::Scene*) /home/sybren/workspace/blender-git/blender/intern/cycles/render/shader.cpp:358
    #1 0x55feb0243dbc in ccl::BlenderSync::find_shader(BL::ID&, ccl::vector<ccl::Shader*, ccl::GuardedAllocator<ccl::Shader*> >&, ccl::Shader*) /home/sybren/workspace/blender-git/blender/intern/cycles/blender/blender_shader.cpp:49
    #2 0x55feb01d0c0b in ccl::BlenderSync::sync_light(BL::Object&, int*, BL::Object&, BL::Object&, int, ccl::Transform&, bool*) /home/sybren/workspace/blender-git/blender/intern/cycles/blender/blender_object.cpp:200
    #3 0x55feb01d2b4a in ccl::BlenderSync::sync_object(BL::Depsgraph&, BL::ViewLayer&, BL::DepsgraphObjectInstance&, float, bool, bool, ccl::BlenderObjectCulling&, bool*) /home/sybren/workspace/blender-git/blender/intern/cycles/blender/blender_object.cpp:321
    #4 0x55feb01d62b7 in ccl::BlenderSync::sync_objects(BL::Depsgraph&, float) /home/sybren/workspace/blender-git/blender/intern/cycles/blender/blender_object.cpp:552
    #5 0x55feb0182e40 in ccl::BlenderSync::sync_data(BL::RenderSettings&, BL::Depsgraph&, BL::SpaceView3D&, BL::Object&, int, int, void**) /home/sybren/workspace/blender-git/blender/intern/cycles/blender/blender_sync.cpp:213
    #6 0x55feb01618fa in ccl::BlenderSession::synchronize(BL::Depsgraph&) /home/sybren/workspace/blender-git/blender/intern/cycles/blender/blender_session.cpp:881
    #7 0x55feb013c932 in sync_func /home/sybren/workspace/blender-git/blender/intern/cycles/blender/blender_python.cpp:399
    #8 0x7f365d011948 in _PyMethodDef_RawFastCallKeywords (/usr/lib/x86_64-linux-gnu/libpython3.7m.so.1.0+0x244948)
    #9 0x7f365d0126b4 in _PyCFunction_FastCallKeywords (/usr/lib/x86_64-linux-gnu/libpython3.7m.so.1.0+0x2456b4)
    #10 0x7f365ce43b0f in _PyEval_EvalFrameDefault (/usr/lib/x86_64-linux-gnu/libpython3.7m.so.1.0+0x76b0f)
    #11 0x7f365ce45a42  (/usr/lib/x86_64-linux-gnu/libpython3.7m.so.1.0+0x78a42)
    #12 0x7f365ce43649 in _PyEval_EvalFrameDefault (/usr/lib/x86_64-linux-gnu/libpython3.7m.so.1.0+0x76649)
    #13 0x7f365ce45a42  (/usr/lib/x86_64-linux-gnu/libpython3.7m.so.1.0+0x78a42)
    #14 0x7f365d0121e2 in _PyFunction_FastCallDict (/usr/lib/x86_64-linux-gnu/libpython3.7m.so.1.0+0x2451e2)
    #15 0x55feafac62de in bpy_class_call /home/sybren/workspace/blender-git/blender/source/blender/python/intern/bpy_rna.c:8295
    #16 0x55feafecf836 in engine_view_update /home/sybren/workspace/blender-git/blender/source/blender/makesrna/intern/rna_render.c:224
    #17 0x55febc051ed3 in ED_render_scene_update /home/sybren/workspace/blender-git/blender/source/blender/editors/render/render_update.c:138
    #18 0x55feaf92277d in DEG::deg_editors_scene_update(DEGEditorUpdateContext const*, bool) /home/sybren/workspace/blender-git/blender/source/blender/depsgraph/intern/depsgraph_update.cc:45
    #19 0x55feaf922031 in DEG_ids_check_recalc /home/sybren/workspace/blender-git/blender/source/blender/depsgraph/intern/depsgraph_tag.cc:768
    #20 0x55feaf4a3172 in scene_graph_update_tagged /home/sybren/workspace/blender-git/blender/source/blender/blenkernel/intern/scene.c:1575
    #21 0x55feaf4a31b2 in BKE_scene_graph_update_tagged /home/sybren/workspace/blender-git/blender/source/blender/blenkernel/intern/scene.c:1582
    #22 0x55feb008f73f in wm_event_do_depsgraph /home/sybren/workspace/blender-git/blender/source/blender/windowmanager/intern/wm_event_system.c:369
    #23 0x55feb008f98d in wm_event_do_refresh_wm_and_depsgraph /home/sybren/workspace/blender-git/blender/source/blender/windowmanager/intern/wm_event_system.c:395
    #24 0x55feb0090a2c in wm_event_do_notifiers /home/sybren/workspace/blender-git/blender/source/blender/windowmanager/intern/wm_event_system.c:560
    #25 0x55feb0081d30 in WM_main /home/sybren/workspace/blender-git/blender/source/blender/windowmanager/intern/wm.c:420
    #26 0x55feaefa4ae6 in main /home/sybren/workspace/blender-git/blender/source/creator/creator.c:500
    #27 0x7f36557f1b96 in __libc_start_main (/lib/x86_64-linux-gnu/libc.so.6+0x21b96)
    #28 0x55feaefa4179 in _start (/home/sybren/workspace/blender-git/build_debug/bin/blender+0x2da9179)
The call to shader_map.find(id) returns nullptr in BlenderSync::find_shader(...), which causes the subsequent crash.
