Text objects: 'Truncate' overflow handling of text frames is broken when using non-top alignement.
Closed, ResolvedPublicKNOWN ISSUE
Current Blender master.
Open the attached .blend and see how last frame's truncated text is totally offset from actual frame position. It needs some counter-offset somehow, not sure how to do this with current code though…
Bastien Montagne (mont29) lowered the priority of this task from 90 to 50.Jul 9 2019, 5:25 PM
Bastien Montagne (mont29) created this task.
I'm not sure we actually want truncate to work for any alignment that is not top/top-baseline. That said D5246 fix the most common cases.
But why not? You mean because we truncate last words? Vertical center would still truncate last words, just center the whole thing. Bottom alignment also.
Bastien Montagne (mont29) changed the subtype of this task from "Report" to "Known Issue".Jan 27 2020, 5:07 PM
Bastien Montagne (mont29) edited projects, added Modeling; removed Tracker Curfew.
Would consider that more like a known issue/TODO than a bug actually…
