Text editor becomes out of sync in object mode
Reporting for reference, Tested with a7ac40888f530c12f137b3f6249b6f1dcfae3ea3
With the default startup, perform the following actions.
  • Make the properties editor into a text editor.
  • Add a new test block.
  • Type AA
  • Duplicate the default cube.
  • Undo once
The text in the text editor will be empty.
Note that this is similar to T66658: Text editor becomes out of sync in edit mode.
note there is T66172 as well (not sure this is really a duplicate of T65909...)
Strangely I cannot reproduce that issue here.
Brecht Van Lommel (brecht) lowered the priority of this task from 90 to 50.
Settings as confirmed since this was reported by @Campbell Barton (campbellbarton).
Double checked, this is still happening here (it's asserting which is correct, but in release builds the text vanishes).
I wanted to mention that this may be related to the undo sync issues I'm having while animating. https://developer.blender.org/T66325
I know exactly which version of 2.8 Beta was working properly before the "Undo Keyframe Sync" issue started... Windows 2.8 (8b2b79c2108b) was the last version that worked without Undo Sync issues. It was released sometime around June 5th or 6th. Every version after that one has been out of Sync with Undo.
Hope this helps
Tim
Campbell Barton (campbellbarton) changed the task status from Unknown Status to Resolved.Jul 19 2019, 9:48 AM
