Cannot assign shortcut to Subdivision Surface.
Operating system: windows 10
Graphics card: NVIDIA GeForce GTX 960M
Broken: 2.8
I cannot assign shortcut to subdivision surface.
It was keep adding a new shortcut key and couldn't fix by going to Modifiers > Add Modifier > Subdivision Surface and Right clicking and Assign Shortcut. It should override the setting not keep stacking.
How I fixed: Go to Edit > Preference > and search "add modifier", I found multiple shortcuts assigned to Subdivision Surface.
(forgot to add a few more lines)
And I left only one of them and deleted others, then it worked.
Still not showing proper setting if I go to Modifiers > Add Modifier > Subdivision Surface and Right clicking. It says Assign Shortcut only, even though it's already assigned and should show "Change shortcut / Remove Shortcut". But the shortcut there and working.
@Yurie (prettymatcha)
The multiple Shortcuts are because of the different levels for the Subdivision. If you press Ctrl+2 the (viewport) Subdivison level 2 is added, with Ctrl+5 Level5 is added.
But in general the option to add a Shortkey shouldn't appear like this, I guess. There is no possibility to add a shortcut with the in 2.8 usual way (rightclick/Assign shortcut).
But the same goes for other modifiers. I couldn't add a shortkey to any other modifiers either.
Jacques Lucke (JacquesLucke) lowered the priority of this task from 90 to Low.Aug 7 2019, 2:46 PM
That is probably a limitation in the current system. The shortcut is added to the object.modifier_add operator, and not to a specific modifier type...
Can confirm the issue, but I think this has low priority.
Thnaks for the report but I was not able to reproduce the problem here.
Assigning shortcuts to modifiers just works fine.
You probably chose a shortcut that conflicts with another one.
In this case, please use other channels for help:
https://www.blender.org/community/
