Array in object offset with empty dissapear
Closed, ResolvedPublicKNOWN ISSUE
Operating system: Windows 10
Graphics card: NVIDIA Geforce 920MX
Broken: 2.80 RC1 and RC2
A cube with array modifier in object offset and an empty.
Open the blend file and move or scale the empty.
Thank you!
Germano Cavalcante (mano-wii) lowered the priority of this task from 90 to 50.
The problem here is that the object gets too large causing the coordinates of the BoundBox to begin to suffer with float precision.
I know that BoundBox is used by the draw_manager for culling test.
@Clément Foucault (fclem), is there anything we can do here? Where should we look in the code?
Germano Cavalcante (mano-wii) changed the subtype of this task from "Report" to "Known Issue".Jan 24 2020, 7:13 PM
This is a limitation with absurdly large objects. There is not much we can do.
Thanks a lot Clément and all devs! :) All the best.
